Use this category:
Solved installation error
We work already during our leisure time without getting something for it. Still you expect, that we on weekends also always are available?martinsai wrote: ????? no help??????
I can take a quick look, but can not promise that I find the problem. Have you a full backup? Better would be a test page with a clone of the page.yes, without any problems. can I give you access to the website?
You can send the access data to rich@*kunena.org (address withouit star).
I'm sorry, it was my mistake. I forgot to write, you must also enable the Joomla debug mode so that it shows a error message.rich wrote: Please go to the Joomla Global Configuration (tab Server) and set Error Reporting to Maximum. Then the error message should be more exact.
You need not pay for me, the Kunena project is free, also the support here in this forum.thnx, if you find error plz send me a small invoice, I will pay. i will contact u through mail, thnx
The last version which is possible to install is Kunena 5.1.6, newer versions are not possible. But it shows no categories in the category manager and in the Kunena user list you get this error: Notice: Undefined property via __get(): banned in /libraries/kunena/user/user.php on line 2170
My questions now:
1. Which Kunena version was installed before you tried the upgrade.
2. Which Joomla version was installed before
3. With which versions (Joomla and Kunena) it has worked as expected
it is so many content, I hardly can send u everything via attachment. I gave you access via mail. can you check?
to your points:
1. There was no Kunena installed before. Just today i deinstalled everything of kunena, even in database I deleted all kunena tables but still same error. after i reinstalled kunena but still same error
2. It was Joomla 3.9.4.
3. Joomla worked fine including many extensions, just kunena, my last step in this project - did not work for a second.
Ah.. thats very helpfull. So you have no problem when I remove completely Kunena (via backend Kunena tools) and try again a installation.1. There was no Kunena installed before.
But maybe I found already the problem (not sure), I need to check it.
