Use this category:
Solved installation error
5 years 1 month ago #1 by martinsai
installation error was created by martinsai
Hi Guys,
I use Joomla 394 and tried to install latest version. I cleaned cache, database, i used different browsers. server config is ok. what else can be the problem? see attachment
cheers martin
Attachment not found
5 years 1 month ago #2 by rich
Replied by rich on topic installation error
Please go to the Joomla Global Configuration (tab Server) and set Error Reporting to Maximum. Then the error message should be more exact.
5 years 1 month ago #3 by martinsai
Replied by martinsai on topic installation error
Hi Rich,
I did as you wrote. There is no error message, just the process of intalling stops as the pic in my first post shows. The kunena window opened but the process stopped.
5 years 1 month ago #4 by rich
Hmm... strange. Please go in the backend to Components and click on "Kunena Forum" if exists this link. Maybe then you can see more.
5 years 4 weeks ago #5 by eatget
Replied by eatget on topic installation error
Hello everybody,
I get the same issue with Kunena v5.1.10.1 and Joomla 3.9.4
Any idea ?
5 years 4 weeks ago #6 by rich
Also when you mean it is the same issue, without error message we can only guess.
5 years 4 weeks ago #7 by martinsai
even with max. error message in the backend>components>kunena i get this, see attachement
5 years 3 weeks ago #8 by rich
Please try following:
Download Kunena, unzip and open the file.
The folder "packages" contain 5 zip files. Install this zip files one by one.
Then go in the backend to Extensions -> Plugins and check whether the Kunena system plugin is enabled. Then try to install Kunena again.
The following user(s) said Thank You: reason
5 years 3 weeks ago #9 by martinsai
My god i am really geting tired. I intalled all the 5 extensions in the package folder one by one but the same issue is there. Once I open the component the installation process stoppes after around 2%. as already posted with an image.
can you not help me???
5 years 3 weeks ago #10 by rich
It's very hard to help without error message. It can be many things which cause this problem. It's possible, to install other components?
Time to create page: 0.546 seconds
