Solved Hide / disable login
*** Topics merged by moderator ***
Hopefully this may help someone else.
G'day, GB1Kodiak, and welcome to the forum.
You will find the answer here in this topic.
www.kunena.org/docs/Disable_%28or_hide%29_the_login_form
but this isn't what i wanted.
i am trying to hide the profile area.
Do you understand better now? :dry:
In your first message you showed us a picture of the website here (at www.kunena.org ). Perhaps you have something completely different at your website? Perhaps you are not even using the K 3.0.5 Blue Eagle template? Perhaps you are not using K 3.0.5? Perhaps you did not store the changes where you should have stored the changes? Perhaps the CSS changes you made were overridden somewhere else? Did you look at a web design tool, like Firebug , to double check that the CSS changes were downloaded to your browser? I would check all these things.
Add the following lines to the end of your Joomla site template CSS file[2]:
Code:#Kunena td.kprofileboxcnt, .kprofilebox-left { display: none; }
Can you please tell me exactly which CSS file to edit and in which folder I will find it in. Thanks
You need to add this css on your joomla template css
