Solved Hide / disable login
10 years 10 months ago #1 by jeyjey
Hide / disable login was created by jeyjey
Please excuse me, I am sorry, I am not finding the login module settings. Because I want login by the joomla homepage, I whould like to disable the kunena login module in the kunena forum. Thanks.
10 years 10 months ago #2 by xillibit
Replied by xillibit on topic Hide / disable login
The login part that you can see below the kunena tabs, ISN'T the kunena login module.
10 years 10 months ago #3 by sozzled
Replied by sozzled on topic Hide / disable login
The technique to hide or disable the login form in K 3.0 is the same as the technique used in K 2.0. The technique is explained in the topic Hide / disable login .
10 years 9 months ago #4 by sozzled
10 years 6 months ago - 10 years 6 months ago #5 by afterburner
hello guys !
how to delete login and registration info on top of the forum ?
i use another plugin for this .
Last edit: 10 years 6 months ago by afterburner.
10 years 6 months ago #6 by baazza
رضيت بالله ربا وبالاسلام دينا وبمحمد صلى الله عليه وسلم رسولا
testify & witness that there is no god worthy of being worshipped other than Allah and that Mohammad is His Messenger
The following user(s) said Thank You: afterburner
10 years 6 months ago - 10 years 6 months ago #7 by sozzled
*** Topics merged ***
Last edit: 10 years 6 months ago by sozzled.
10 years 2 months ago #8 by DrTodd
Hi There,
I am new to Kunena, so please accept my apology for asking a dumb question. I am trying to get rid of the box that is between the Kunena Menu and the Breadcrumbs (see attached pic). I have tried turning off everything in the back end to see if that would make it go away and have scoured the forums to no avail.
Is this something that can be done easily or will this have to be done in the .php files?
Is there a module map for Kunena forums that names the different areas?
Thank you for sharing your knowledge.
Todd
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 90M | Max file upload: 7M
Joomla default template details : Lighthouse_j3 | author: arrowthemes | version: 1.1.3 | creationdate: Unknown
Kunena default template details : NTS Kinfinite | author: Nice Theme Store | version: 3.0.4 | creationdate: 2013-05-25
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Plugins: None
10 years 2 months ago #9 by sozzled
G'day, DrTodd, and welcome to Kunena.
This is not a dumb question! This question has been asked dozens of times on the forum. The "box" is called the Kunena profile box which is where there is a login form. If you hide or disable the login form it is easy to do. It is also easy to completely remove the profile box. This articule in the Wiki will show you how to do those things: Disable (or hide) the login form .
The following user(s) said Thank You: DrTodd
10 years 2 months ago #10 by DrTodd
YOU ROCK!!!!
Worked Perfectly!
Thank you very much.
Todd
(Stress level just dropped 10 points)
Time to create page: 0.569 seconds
