- Thank you received: 2
Question Installation fails. No access to "/site/administrator.index.php
- lister171254
- Topic Author
7 years 11 months ago #11
by lister171254
Replied by lister171254 on topic Installation fails. No access to "/site/administrator.index.php
Following is my workaround for this.
I'm running apache on 64 bit Ubuntu
Once Kunena is installed/upgraded reverse the changes and restart Apache
As an aside, it would be great if the developers could fix this
- Edit the file /etc/modsecurity/modsecurity.conf
- Comment out the two lines starting with SecRule MULTIPART_UNMATCHED_BOUNDARY "!@eq 0" \
"id:'200003',phase:2,t:none,log,deny,msg:'Multipart parser detected a possible unmatched boundary.'" - Restart Apache
The following user(s) said Thank You: xristo
7 years 11 months ago #12
by xillibit
Replied by xillibit on topic Installation fails. No access to "/site/administrator.index.php
There is an issue opened on modsecurity similar to our :
github.com/SpiderLabs/ModSecurity/issues/652
7 years 10 months ago #13
by xristo
Replied by xristo on topic Installation fails. No access to "/site/administrator.index.php
so for Kunena to install, security on entire server needs disabled now?
As the OP mentioned, no other joomla component requires this and it's hard to believe such a wonderful (previously stable) component would require such a thing.
Are there plans for a stable build of Kunena to work normally (install normally) with any version of Joomla?
- lister171254
- Topic Author
7 years 10 months ago #14
by lister171254
The latest version pkg_kunena_v4.0.11_2016-06-05.zip installs without any issues
7 years 10 months ago #15
by xristo
Yes it does, installed smoothly. Thank you Kunena team and most appreciated the update lister171254
lister171254 wrote: The latest version pkg_kunena_v4.0.11_2016-06-05.zip installs without any issues
Time to create page: 0.486 seconds
