Solved Hiding LogIn
7 years 11 months ago #1
by Merma001
Hiding LogIn was created by Merma001
HI
I am running Joomla 3.5.1
Kunena 4.0.10
My Template is from Joomlashack (Onyx)
I am using Kunena a bit differently than most as I am the only member.
When I have a new client I issue them a claim check number and they come to my website to check progress (I repair pro audio gear)
They input that claim check number into a search box that will find their thread.
where they can check the status of the work being done (which saves me a ton of telephone time)
OK Question...
when not logged in (as in; all my clients) there is a Log In box at the top of the forum.
How do I have that NOT show up on the forums?
Currently the site is Joomla 2.5 with the Discussions forum (which works great)
But I am rebuilding the site in Joomla 3.5.1 and "Discussions" is not available for that version.
I really want to use Kunena for this (as I run a full forum with Kunena elsewhere and love the options)
Please help!
This
is a screen of the box I want to remove.
Kunena 4.0.10
OK Question...
Please help!
This
7 years 11 months ago - 7 years 11 months ago #2
Replied by sozzled on topic Hiding LogIn
This should still work:
I hope that helps
- Go to Kunena plugins and look at the settings for the Kunena - Joomla Integration plugin: Kunena Forum » Plugins » Kunena - Joomla Integration
- Select the Basic tab
- Set the value Enable Joomla Login = No
I hope that helps
Last edit: 7 years 11 months ago by sozzled.
The following user(s) said Thank You: Merma001
7 years 11 months ago #3
by Merma001
Replied by Merma001 on topic Hiding LogIn
:silly: worked like a charm thank you
Time to create page: 0.538 seconds
