Solved font colors
8 years 1 month ago #1
by crs1305
font colors was created by crs1305
I have a white font in the forum content (probably inherited after sites default font color). That makes the content nearly invisible. Where can I change the color? It's my first day with Kunena - so please be forgiving.
- 9themestore
- Premium Member
8 years 1 month ago #2
by 9themestore
Replied by 9themestore on topic font colors
Hi crs1305,
Normally the font color inherit font colors of your joomla template. So if you want to change font color of your forum you can add below CSS rules to the template.css file.
Note: The template.css file in the css folder of your active joomla template.
Hope this helps
#Kunena, #kunena {
color: #333333; /* You can change to your color code */
Hope this helps
The following user(s) said Thank You: crs1305
8 years 1 month ago #3
by crs1305
Replied by crs1305 on topic font colors
Thanks a lot - works fine. But I still have some inherited font colors (in statistics module and in user info on the left in the forum) What code is for that?
And another issue: user info on the left and the top tabs have inherited the joomla list markings). How to remove that?
I'll really apreciate if you can help in these too.
8 years 1 month ago #4
by crs1305
Ok, already found the solution.Topic closed.
Time to create page: 0.485 seconds
