Solved Advertisment / banner between posts
8 years 4 months ago #1 by Nikiniko
I searxhed first and i found this :
www.kunena.org/forum/k-3-0-general-templ...een-messages-of-post
That has a link to go here :
www.kunena.org/docs/Module_Positions
and with the use of ?tp=1 saws the positions.
Now if i want to ass a banner betwin posts the position is :
Position: kunena_msg_4 [ Style: xhtml outline]
kunena_msg_4
What about if i want to add a banner every 3 or 5 posts ?
How can i do it ?
8 years 4 months ago #2 by rich
It depends on how many posts per page are displayed.
Example 9 posts:
Copy the module 2 x and use
original module to kunena_msg_3
copy 1 to kunena_msg_6
copy 2 to kunena_msg_9
The following user(s) said Thank You: Nikiniko
8 years 4 months ago - 8 years 4 months ago #3 by Nikiniko
Example 20 posts for evey 5 posts
Copy the module 2 x and use >>>>>>>>>>>>>>> what is 2 x ? is it module's number? example 545 ?
original module to kunena_msg_0 >>>>>>>>>>>> is it before first post ?
copy 1 to kunena_msg_5
copy 2 to kunena_msg_10
copy 3 to kunena_msg_15
copy 4 to kunena_msg_20
And where i put all this ?
Last edit: 8 years 4 months ago by Nikiniko.
8 years 4 months ago #4 by Nikiniko
Anyone ?
8 years 4 months ago #5 by 810
you need to create a new module, for each option like kunena_msg_5.
then a new one for kunena_msg_10, kunena_msg_15 ect.
8 years 4 months ago #6 by rich
Copy the created module as often as you need it.
kunena_msg_0 is not a module positiion. For advertising before first post use the position kunena_topictitle
Here is a video tutorial: How to Use the Joomla Custom Module
8 years 4 months ago #7 by Nikiniko
Ok got it !
I really thank you.
It would be good idea if you create something similar inside Kunena admin,
like other forum have.
Even for paid extension it will be very nice and usefull.
Thank you again both.
Time to create page: 0.497 seconds
