- Thank you received: 5
Solved CAPTCHA only in the first post
If yes is it possible to choose the kind of CAPTCHA ?
I mean letters, numeric captcha,pictures,click to confirm that you are human,etc
Yes and no. It depends whether you use the Crypsis template or some other template.Nikiniko wrote: If yes is it possible to choose the kind of CAPTCHA ?
Yes, Kunena uses Google reCAPTCHA. Yes, Crypsis uses the Joomla Captcha - ReCaptcha plugin settings to choose between version 1.0 or 2.0 of Google reCAPTCHA. If you use a "non-HMVC" template—Crypsis is the only HMVC template in existence—the answer is no. If you use a "non-HMVC" template you use the Kunena configuration settings irrespective of the Joomla Captcha - ReCaptcha plugin settings. No, after you have chosen the Kunena template you will use (remember, Google reCAPTCHA is the only CAPTCHA software that operates with Kunena) you cannot "choose" how the reCAPTCHA will be displayed except to refine the colour scheme a little.
The article Using CAPTCHA spam protection in Kunena contains more information.
i already fixed it.
I dont know how to change it ,
but when i will have time i will try it.
Thank you anyway.
