Solved How can I setup my forum so that members can post?
10 years 7 months ago - 10 years 7 months ago #1 by Mattak
Hi
I try to set my Kuena forum up, so all can read, but only registreted can post.
1 forum categori (sign up - help) all can read and post.
I try with usergroup public, and usergroup guest, but get no access.
I think it´s must be very easy, but certainly my brain is not clever enough :S
Mattak
Just see my config was not att.
Last edit: 10 years 7 months ago by Mattak.
The topic has been locked.
10 years 7 months ago #2 by Mattak
No help?
I try to add my config Again...
10 years 7 months ago #3 by 810
Backend- category manager- select a category - category permissions - Set "Primary User Group" to guest. and "User Groups Allowed To Post" to registered.
Do that for all categories.
Regards 810
10 years 7 months ago #4 by Mattak
Hi
Thx for ur reply, but I try many times before!
Have att. the new configuration
Mattak
10 years 7 months ago #5 by 810
just paste here your configuration:
Then i can see it
10 years 7 months ago #6 by Mattak
htaccess: Exists | PHP environment: Max execution time: 3000 seconds | Max execution memory: 256M | Max file upload: 100M
Joomla default template details : jsn_boot_pro | author: JoomlaShine.com | version: 2.1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Third-party components: CommunityBuilder 1.9
Plugins: None
10 years 7 months ago #7 by 810
ok, i see the problem
Go to backend- kunena config - security - change "Registered Users Only" to No.
Regards 810
10 years 7 months ago #8 by Mattak
exactly!
Thank you
Mattak
10 years 7 months ago #9 by sozzled
All new users should read this topic. it shows how quickly simple problems like these can be solved when we can see the Kunena configuration report. :woohoo:
Time to create page: 0.593 seconds
