This category is for discussing issues with the K 3.0 Blue Eagle template.
Question changing default colors
9 years 1 day ago #1 by squeak251
I am trying to change the default colors on Blue Eagle.
I have changed the parameters, but it is still showing the default colors. Do I have to change the color manually in the css? If I do, which CSS file is it?
8 years 11 months ago #2 by 810
Replied by 810 on topic changing default colors
you need to change it on the -min css files.
Or you can turn debug on. on the kunena configuration
8 years 11 months ago - 8 years 11 months ago #3 by sozzled
Replied by sozzled on topic changing default colors
squeak251 wrote: I am trying to change the default colors on Blue Eagle.
Hi there. I am not sure that I totally understand the question. When you wrote that you "changed the parameters", which parameters (in the Kunena Template Manager) did you change and what value(s) did you change them to? I remember that there was a problem with the Kunena Template Manager in an older version of Kunena—trying to store certain named values—so it may help to know which version of Kunena we are discussing.
810 wrote: You need to change it on the -min css files ...
Are you saying that the Kunena Template Manager for K 3.0.8 does not allow you to change the default colour parameters for the Blue Eagle template? :ohmy:
Last edit: 8 years 11 months ago by sozzled.
8 years 11 months ago #4 by squeak251
Replied by squeak251 on topic changing default colors
Yeah, I changed the parameters in the template manager, but the colors stayed the same on the site.
I will edit the template tomorrow, but wish the parameters would work. The parameters file has been changed, just not coming through.
8 years 11 months ago - 8 years 11 months ago #5 by sozzled
squeak251 wrote: Yeah, I changed the parameters in the template manager, but the colors stayed the same on the site. I ... wish the parameters would work. The parameters file has been changed, just not coming through.
Which parameters did you change? Perhaps the colours have not changed if your website is cached. It may be an idea to clear the site cache (and possibly your browser cache, too).
Also, which version of Kunena are you using? If this is an issue with the current version of Kunena then I am sure that the whole community needs to know about it. If the current version of Kunena Template Manager does not honour the parameter changes then there is a major problem here.
Your configuration report may help the forum moderators and developers learn more about your problem.
8 years 11 months ago #6 by squeak251
from the component page on the Joomla Admin side, I go to the template, then parameters.
I am using 3.0.8
My config is:
htaccess: Exists | PHP environment: Max execution time: 180 seconds | Max execution memory: 256M | Max file upload: 256M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.8 | creationdate: 2015-04-05
Kunena version detailed: Kunena 3.0.8 | 2015-04-05 [ Imperium ]
Plugins: None
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1
8 years 11 months ago - 8 years 11 months ago #7 by rich
Replied by rich on topic changing default colors
It should work. Empty your Joomla and browser cache after change.
Last edit: 8 years 11 months ago by rich.
8 years 11 months ago #8 by squeak251
I've done that, but still getting the same issue.
My colleague is also experiencing the same issue on his PC, he is in New York, I am in London.
8 years 11 months ago #9 by rich
The best way, you search the codes with firebug, copy the found codes and add these codes at the end in your Joomla! custom.css (or template.css if the file doesn't exists) "templates/yourtemplate/css/custom.css", modify and save it.
Please see also this doc: www.kunena.org/docs/Changing_Template_an...Colours_-_the_Basics
Time to create page: 0.604 seconds
