- Thank you received: 1
Please Read This First:
Please read the guides posted as sticky topics in this category. For a quicker response, please give as much information to help us understand the problem (see How To Ask Questions The Smart Way and What information should I include when I ask for help (including how to post my configuration report)? ).
This category is only for reporting defects with K 2.0 Please read, before you post, Before you post your question, read this first .
Do not use this category:
- if this website ( www.kunena.org ) works but works differently to how you expected
- for requests to add or remove the standard features of Kunena;
- for questions commonly asked or "how to" in nature (see the FAQs menu tab above);
- for help with Kunena versions that are not the latest stable release; or
- for general Joomla or website administration matters
You must include your K 2.0 configuration report; if you do not include your configuration report, your topic may be closed (locked) or deleted without any further warnings from the moderators.
Merged Typo in helper.php causes problem with reverse ordering (last post first)
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
- GJSchaller
- Premium Member
Geoffrey Schaller
Technical Officer
Knight Realms
I have some information for remind, if needed in the future :
- GJSchaller
- Premium Member
Actually, even on a new article - the option to discuss it does not appear at the bottom of the page, if the thread does not already exist.
Geoffrey Schaller
Technical Officer
Knight Realms
- GJSchaller
- Premium Member
Geoffrey Schaller
Technical Officer
Knight Realms
GJSchaller wrote: I'm still running into the same issue as before, with the other fix - if an article had a page previously, and the discussion topic was deleted, there is no longer a link to discuss the article at the bottom of that article.
This seems to be so, unless one goes to the trash manager and deletes the old post there. Then the topics show up in the article by way of link after having been deleted, at least in my case.
And thanks xillibit, the change allowed the discuss plugin to work without error, however, the above mentioned seems to be a separate issue.
xillibit wrote: A way to fix it, in /plugins/content/kunenadiscuss/kunenadiscuss.php line 381, modify like that :
Code:if ($topic->exists() ) $linktitle = JText::sprintf ( 'PLG_KUNENADISCUSS_DISCUSS_ON_FORUMS', $topic->getReplies() );
Awesome! This fixed everything!
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
- GJSchaller
- Premium Member
Geoffrey Schaller
Technical Officer
Knight Realms
- Peakoverload
GJSchaller wrote: I'm still stuck with links to threads not appearing on articles, unless the topic is already in existence. This makes the "Create topic on Reply" option unusable for me.
I'm getting this too. If I have the discuss plugin set to create topic on first visit then I don't get an error but if I have it set to first reply then I get:
Warning: Invalid argument supplied for foreach() in /public_html/administrator/components/com_kunena/libraries/forum/message/helper.php on line 212
I've tried changing line 381 in kunenadiscuss.php from:
to
but this has had a rather bizarre result. Now any article which has already had a forum thread created shows normally but the discuss plugin is completely missing from any article that hasn't previously had a thread started. This happens regardless of whether I have the plugin set to first visit or first reply. If set to first visit no threads are created in the forum and if set to first reply there is no discuss button showing with which to create a new thread!
My config:
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 256M | Max file upload: 200M
ID Name Menutype Link Path 110 Forum kunenamenu view=home&defaultmenu=112 forum 111 Index kunenamenu view=category&layout=list forum/index 112 Recent Topics kunenamenu view=topics&mode=replies forum/recent 113 New Topic kunenamenu view=topic&layout=create forum/newtopic 114 No Replies kunenamenu view=topics&mode=noreplies forum/noreplies 115 My Topics kunenamenu view=topics&layout=user&mode=default forum/mylatest 116 Profile kunenamenu view=user forum/profile 117 Help kunenamenu view=misc forum/help 118 Search kunenamenu view=search forum/search 142 Forum mainmenu view=home&defaultmenu=110 forum2
Joomla default template details : jsn_boot_pro | author: JoomlaShine.com | version: 2.0.0 | creationdate: 03/11/2013
Kunena config settings: board_offline 0 enablerss 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 disemoticons 0 template blue_eagle showannouncement 1 avataroncat 0 catimagepath category_images showchildcaticon 1 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatarupload 1 allowavatargallery 1 avatarquality 75 avatarsize 2048 imageheight 800 imagewidth 800 imagesize 750 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 500 showranking 1 rankimages 1 userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us sessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 defaultpage recent default_sort asc sef 1 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 70 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 show_list_time 168 show_session_type 0 show_session_starttime 0 userlist_allowed 1 userlist_count_users 1 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 0 thankyou_max 10 email_recipient_count 0 email_recipient_privacy bcc captcha_post_limit 0 keywords 0 userkeywords 0 image_upload registered file_upload registered topic_layout flat time_to_create_page 1 show_imgfiles_manage_profile 1 hold_newusers_posts 0 hold_guest_posts 0 attachment_limit 8 pickup_category 0 article_display intro send_emails 1 fallback_english 1 cache 1 cache_time 60 iptracking 1 rss_feedburner_url | Joomla! detailed language files installed:Warning: Spoiler!Kunena - AlphaUserPoints Disabled
Kunena - UddeIM Disabled
Plugins: Search - Kunena Search 2.0.4 | Content - Kunena Discuss 2.0.4
Modules: Kunena Latest 2.0.4 | Kunena Stats 2.0.4 | Kunena Login 2.0.4 | Kunena Search 2.0.4
