Question No Sticky Button (and others)
10 years 9 months ago #1 by drukman
Using version 2.0.4 with Joomla 2.5.9
Browsing the forum as admin (or moderator) few buttons are missing:
Sticky, Lock, Favorite
Thanks - Drukman.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2000M
Joomla default template details : ja_purity_ii | author: JoomlArt.com | version: 2.5.3 | creationdate: Nov 2012
Kunena default template details : Blue Eagle_rtl 2.0 | author: Kunena Team | version: 2.0.0-RC3 | creationdate: 2012-06-22
Plugins: None
10 years 9 months ago #2 by sozzled
Might be a problem your Kunena right-to-left template (which was designed for K 2.0.0 RC3 and it probably doesn't work with K 2.0.4)
Might be a problem with the JA_Purity-ii site template.
Might be a problem with your Joomla menu (see Kunena Menu issues
I wish I could be more help but I really can't say. My guess is that the problem is caused by your Kunena template.
10 years 9 months ago - 10 years 9 months ago #3 by drukman
sozzled wrote: Might be a problem your Kunena right-to-left template (which was designed for K 2.0.0 RC3 and it probably doesn't work with K 2.0.4)
Thanks.
1. Checked both with rtl & non-rtl version of this template.
Any other template (rtl or even non rtl) you can share a link to, that is worth checking with ?
2. In the mainmenu I have only one "Menu Item Alias" that points to the 1st tab of the kunena menu & there are no trashed menu items.
Last edit: 10 years 9 months ago by drukman.
Time to create page: 0.497 seconds
