- Thank you received: 3
configuration report
Question Avatar Issues
- originalhandy
- Topic Author
- Junior Member
11 years 1 month ago #1
by originalhandy
Avatar Issues was created by originalhandy
Joomla 2.5.9
Kunena 2.0.4
Was a PHPBB forum, upgraded from PHPBB3 to Kunena 1.5 then up to 2.0
Website www.clanwta.com
When I had PHPBB3 I had several different folders people could chose from for Avatars. Women/Animated/Funny/Uploaded. When I moved over the forums everybody kept their avatars which was good. If somebody goes to Edit their profile and go to Avatar Image there is a dropdown of the above folders but when selected it auto takes you back to the "User Account" tab.
Uploaded animated GIF's arent animated even though they are within the allowed kb.
Any ideas ?
Kunena 2.0.4
Any ideas ?
11 years 1 month ago - 11 years 1 month ago #2
by Moonstone
Replied by Moonstone on topic Avatar Issues
The redirect issue has been reported as a bug. Unfortunately, xillibit has stated he doesn't know how to fix it, so I'm not sure how/when it will be addressed.
It's a very annoying issue for me because I have a huge avatar gallery that can no longer be utilized.
Here is the existing thread:
www.kunena.org/forum/K-2-0-Support/12442...nal-avatar-galleries
Last edit: 11 years 1 month ago by Moonstone.
11 years 1 month ago #3
by xillibit
Replied by xillibit on topic Avatar Issues
You take a proposed fix from here : github.com/Kunena/Kunena-2.0/issues/1110 , i need feedback on it
- originalhandy
- Topic Author
- Junior Member
11 years 1 month ago - 11 years 1 month ago #4
by originalhandy
Replied by originalhandy on topic Avatar Issues
I applied
github.com/xillibit/Kunena/blob/46a8ae6b...s/user/view.html.php
but still get the same issue.
Ive subscribed to teh topic so I will get back soon as ideas come.
Last edit: 11 years 1 month ago by originalhandy.
The following user(s) said Thank You: Moonstone
- originalhandy
- Topic Author
- Junior Member
10 years 10 months ago #5
by originalhandy
Still getting the same issue in K3.
10 years 10 months ago #6
by rich
Replied by rich on topic Avatar Issues
I've tested now. With K 3.0 it should work. You have a spaces in your folder name? Then it does not work.
- originalhandy
- Topic Author
- Junior Member
10 years 10 months ago #7
by originalhandy
OK no gaps and it works.
I have an issue as to where if they select an animated GIF it only animates when you look at their profile where its full size. If its small, in the forum view its a still.
Also you cannot upload a gif and have it animated.
Time to create page: 0.541 seconds
