Merged Before you post your question, read this first
Please see msg #1 in this topic for your answers. The answer is not just a simple case of turning off "build title spans". I counted 15 Javascript library sources loaded on your site (before I stopped counting) and any one or more those could be clobbering Mootools. Which one(s), I don't know.
gantry-splicemenu.js
The only thing I dont find is why Tabs on Menu of Kunena not appear.
Any sugestion?
In advance I do not upgrade from prior version. Is a fresh install of kunena.
From what I read, now kunena menu work like any other from joomla. Is need create a module for assign were the menu will display.
Correct?
Discussion about the Kunena menu is off-topic to this topic. Please used the other topic, referred to in my last reply to you, about menu issues.
This topic is mostly about Javascript library conflicts with Joomla [Mootools].
I turn Kunena to debug mode too see If there is an error and I received this (maby help you)
JDatabaseMySQLi::query: 1146 - Table 'sitenamedatabase.xxx_kunena_config' doesn't exist SQL=SELECT template FROM dsx_kunena_config ORDER BY id DESC LIMIT 1
What else should I look?
try to save your kunena configuration settings in backend
