Question Making JomSocial/Kunena look the same
- mattlindsay
- Topic Author
13 years 5 months ago #1
by mattlindsay
Making JomSocial/Kunena look the same was created by mattlindsay
Does anyone have any good ideas for how to make a fresh install of both kunena and JomSocial look the same? One has a green template, the other a blue one. it makes it very obvious that they are two different applications.
For bonus points... anybody know a way to make them both use the same menu bar?
Cheers guys
Matt
Cheers guys
Matt
13 years 5 months ago #2
by zbabyface
Replied by zbabyface on topic Re: Making JomSocial/Kunena look the same
Same menu bar......yeah....not happening, however, you can get them to look the same.... or pretty damn close... it takes alot of css / image fudging....
- mattlindsay
- Topic Author
13 years 5 months ago #3
by mattlindsay
Replied by mattlindsay on topic Re: Making JomSocial/Kunena look the same
Thanks zbabyface.
Any other ides for my install?
13 years 5 months ago #4
by fxstein
Replied by fxstein on topic Re: Making JomSocial/Kunena look the same
You will need to change one of the two templates. All the styling of Kunena and JomSocial can be customized through their respective CSS files - including the toolbar.
- mattlindsay
- Topic Author
13 years 5 months ago #5
by mattlindsay
Thanks fxstein.
Not being a css/template guru (or even having a clue!) can anyone reccomend two templates that look the same for JomSocial and Kunena?
Cheers
Matt
Cheers
Matt
13 years 3 months ago #6
by 650
Replied by 650 on topic Re: Making JomSocial/Kunena look the same
Hi Matt, do you find the solution for this or anyone can suggest to solve this solution except edit CSS because it hard to do this? Have any template can serve both?
Time to create page: 0.475 seconds
