Question 406 Not Acceptable Error when installing
Not Acceptable
An appropriate representation of the requested resource /administrator/index.php could not be found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
We are running:
Apache version 2.2.22
PHP version 5.3.10
MySQL version 5.1.62-cll
I have searched for similar errors and someone suggests to make sure .htaccess is enabled in the joomla root directory and ensure mod-rewrite is on. Well looking through the .htaccess file I see the entry: RewriteEngine On
So I assume that is ok, but what do they mean make sure the .htaccess file is enabled? Any help appreciated.
The K 1.6 & K 1.7 Installation Guide provides a lot of information that should help. In particular, you should look at Securing Kunena for information about how to properly setup the folder and file permissions and Search Engine Optimisation (SEO) for advice how to properly setup SEO (and, by extension, your .htaccess file) for a standard Joomla website.
I hope this helps in your case.
- LittleJohn
- Kunena Contributor
Do you know if your host got mod_security enabled?
You can try insert this rule in your '.htaccess' file and see if it helps. If it doesnt, do revert the changes asap!
I would advise you to discuss the possible implications of making those changes, as far as security are concerned, with your web hosting provider.
- LittleJohn
Yes - as you point out yourself - mod_security is there for a reason, and that reason is security! You are far more prone to attacks with it disabled.
As sozzled pointed out too, you should revert the changes and discuss this issue with your hosting provider and find a solution.
