Question Upgrading Issues
- devilstormz
- Topic Author
This is my current setup of the website:
- Joomla 1.5
-Community builder
-Kunena 1.7.0
I have been using Kunena since 1.5 and have had no issues upgrading it. Sadly however, I have encountered an issue when doing the upgrade from 1.7.0 to 1.7.2. After carrying out preliminary steps such as taking backups etc. I run the installer using the joomla install manager and get the following as shown in the image.
So, the first issue was obviously the version numbers but I read on the forums that it was due to the language packs and nothing more.
Secondly its telling me to downgrade ?? I have checked that 1.70 is installed according to the following screenshot.
So i decide to click downgrade to 1.7.0 and then end up with a blank page with the error message
-1- An error occured
A folder already exists.
So then i decided to uninstall kunena which went smoothly, I took a backup of the database and dropped all the tables containing jos_kunena.
Connected to FTP and checked that any folders existed relating to kunena but the unistaller seemed to have removed them all.
I checked the following locations
root/administrator/components/
root/components
root/media
root/modules
root/plugins
Once this was done, I went to re install it and the same error comes up!
So any help/ guidance would be greatly appreciated to resolve this issue. If all else fails could some one tell me how to manually unistall the forums because I thought I removed everything relating to it including entries in the database but apparently not.
Also note the frontend of the website is fully functional which is weird considering it says it has been taken down but backend doesnt work so cannot edit any of the config, categories.
Thanks in advance
Matt
Check directories permissions : root/administrator/components/
root/components
root/media
- devilstormz
- Topic Author
I just created 2 fresh installs one with joomla 1.5.2 and another with 2.5.2
There werent any issues installing the forum whatsoever with the same permissions etc...
So we can rule out any issues with hosting side of things.
Perhaps there is something to do with the database.
EDIT:
I managed to uninstall 1.7.0 and then was able to install kunena 1.6.4 and I was back into the backend. But trying to install 1.6.5 I get the same error so I tried 1.7.0 and it says it has installed but then brings me back to the first screenshot.
Could you just advise me how to manually remove so I can "fresh" install.
Is it possible to include a copy of your configuration report, please?
- devilstormz
- Topic Author
Last PHP Error(s) Reported :: Forum Post Assistant (v1.2.0) : 14th April 2012 wrote: [14-Apr-2012 11:47:55] PHP Warning: Invalid argument supplied for foreach() in /home/tecclan1/public_html/administrator/components/com_comprofiler/plugin.class.php on line 442
Basic Environment :: wrote: Joomla! Instance :: Joomla! 1.5.26-Stable (senu takaa ama busani) 27-March-2012
Joomla! Platform :: Nooku 0.7.0-alpha-2.-alpha ()
Joomla! Configured :: Yes | Writable (777) | Owner: tecclan1 (uid: 543/gid: 539) | Group: tecclan1 (gid: 539) | Valid For: 1.5
Configuration Options :: Offline: 0 | SEF: 0 | SEF Suffix: 0 | SEF ReWrite: 0 | .htaccess/web.config: Yes | GZip: 0 | Cache: 0 | FTP Layer: 0 | SSL: 0 | Error Reporting: -1 | Site Debug: 0 | Language Debug: 0 | Database Credentials Present: Yes
Host Configuration :: OS: Linux | OS Version: 2.6.18-308.1.1.el5xen | Technology: x86_64 | Web Server: Apache | Encoding: gzip,deflate,sdch | Doc Root: /home/tecclan1/public_html | System TMP Writable: Yes
PHP Configuration :: Version: 5.2.9 | PHP API: cgi | Session Path Writable: Unknown | Display Errors: 1 | Error Reporting: 6135 | Log Errors To: error_log | Last Known Error: 14th April 2012 06:47:55. | Register Globals: 1 | Magic Quotes: 1 | Safe Mode: 0 | Open Base: | Uploads: 1 | Max. Upload Size: 10M | Max. POST Size: 8M | Max. Input Time: 60 | Max. Execution Time: 30 | Memory Limit: 48M
MySQL Configuration :: Version: 5.1.61 (Client:5.1.61) | Host: --protected-- (--protected--) | Collation: utf8_general_ci (Character Set: utf8) | Database Size: 1.75 MiB | #of _FPA_TABLE: 113Detailed Environment :: wrote: PHP Extensions :: zip (1.8.11) | libxml () | xsl (0.1) | xmlwriter (0.1) | xmlrpc (0.51) | dom (20031129) | xmlreader (0.1) | xml () | wddx () | tokenizer (0.1) | tidy (2.0) | session () | pcre () | SimpleXML (0.1) | sockets () | SPL (0.2) | standard (5.2.9) | Reflection (0.1) | pspell () | posix () | mysqli (0.1) | mysql (1.0) | mhash () | mcrypt () | mbstring () | json (1.2.1) | imap () | iconv () | hash (1.0) | gettext () | gd () | ftp () | filter (0.11.0) | dbase () | date (5.2.9) | curl () | ctype () | calendar () | bz2 () | bcmath () | zlib (1.1) | openssl () | cgi () | PDO (1.0.4dev) | pdo_sqlite (1.0.1) | SQLite (2.0-dev) | pdo_mysql (1.0.2) | ionCube Loader () | Zend Optimizer () | Zend Engine (2.2.0) |
Potential Missing Extensions :: suhosin |
Switch User Environment (Experimental) :: PHP CGI: Yes | Server SU: Yes | PHP SU: Yes | Custom SU (LiteSpeed/Cloud/Grid): No
Potential Ownership Issues: MaybeFolder Permissions :: wrote: Core Folders :: images/ (755) | components/ (777) | modules/ (755) | plugins/ (755) | language/ (755) | templates/ (755) | cache/ (755) | logs/ (755) | tmp/ (755) | administrator/components/ (777) | administrator/modules/ (755) | administrator/language/ (755) | administrator/templates/ (755) | sites/ (---) |
Elevated Permissions (First 10) :: None components/ (777) | components/com_jsecure/ (777) | components/com_mailto/ (777) | components/com_newsfeeds/ (777) | components/com_rokcandy/ (777) | components/com_rokcandybundle/ (777) | components/com_roknavmenubundle/ (777) | components/com_search/ (777) | components/com_weblinks/ (777) |Database Information :: wrote: Database _FPA_STATS :: Uptime: 232810 | Threads: 1 | Questions: 8872266 | Slow queries: 31 | Opens: 374225 | Flush tables: 5 | Open tables: 1024 | Queries per second avg: 38.109 |
Extensions Discovered :: wrote: Components :: SITE :: Wrapper (1.5.0) | MailTo (1.5.0) | Gantry (3.1.13) | User (1.5.0) | Kunena Forum - English (1.7.0) | WF_FULLSCREEN_TITLE (2.0.12) | WF_XHTMLXTRAS_TITLE (2.0.12) | WF_SEARCHREPLACE_TITLE (2.0.12) | WF_BROWSER_TITLE (2.0.12) | WF_LAYER_TITLE (2.0.12) | WF_LINK_TITLE (2.0.12) | WF_AUTOSAVE_TITLE (2.0.12) | WF_STYLE_TITLE (2.0.12) | WF_CONTEXTMENU_TITLE (2.0.12) | WF_SPELLCHECKER_TITLE (2.0.12) | WF_PREVIEW_TITLE (2.0.12) | WF_DIRECTIONALITY_TITLE (2.0.12) | WF_PRINT_TITLE (2.0.12) | WF_VISUALCHARS_TITLE (2.0.12) | WF_SOURCE_TITLE (2.0.12) | WF_TABLE_TITLE (2.0.12) | WF_CLEANUP_TITLE (2.0.12) | WF_MEDIA_TITLE (2.0.12) | WF_TEXTCASE_TITLE (2.0.12) | WF_IMGMANAGER_TITLE (2.0.12) | WF_ARTICLE_TITLE (2.0.12) | WF_NONBREAKING_TITLE (2.0.12) | WF_INLINEPOPUPS_TITLE (2.0.12) | WF_PASTE_TITLE (2.0.12) | WF_MEDIAPLAYER_JCEPLAYER_TITLE (2.0.12) | WF_FILESYSTEM_JOOMLA_TITLE (2.0.12) | WF_AGGREGATOR_VIMEO_TITLE (2.0.12) | WF_AGGREGATOR_YOUTUBE_TITLE (2.0.12) | WF_LINKS_JOOMLALINKS_TITLE (2.0.12) | WF_POPUPS_JCEMEDIABOX_TITLE (2.0.12) | WF_POPUPS_WINDOW_TITLE (2.0.12) | CB Mambo Author Tab (1.2) | CB Captcha (1.2 RC 2) | Yanc Integration (1.2) | CB Mamblog Tab (1.2) | comprofiler (1. |
Components :: ADMIN :: Configuration Manager (1.5.0) | RokCandy Bundle (1.4) | Installation Manager (1.5.0) | jsecure (2.1.2) | Cache Manager (1.5.0) | Language Manager (1.5.0) | RokNavMenu Bundle (2.11) | Weblinks (1.5.0) | RokCandy (1.4) | Ninja (1.0.0) | Newsfeeds (1.5.0) | Menus Manager (1.5.0) | Search (1.5.0) | Module Manager (1.5.0) | Banners (1.5.0) | Gantry (3.1.13) | Frontpage (1.5.0) | com_kunena (1.7.2) | Kunena Forum - English (1.7.0) | Unknown (-) | Kunena language pack (@kunenaversio) | plg_system_kunena (-) | plg_system_kunena (1.7.0) | System - Kunena (1.7.0) | Kunena (1.7.0) | Messaging (1.5.0) | RokModule (1.2) | Plugin Manager (1.5.0) | Polls (1.5.0) | Editor - JCE (2.0.12) | Unknown (-) | JCE (2.0.12) | Control Panel (1.5.0) | Template Manager (1.5.0) | Free PayPal (1.5.13) | extensions (0.7) | Media Manager (1.5.0) | Trash (1.0.0) | Admintools (2.1.6) | Contact Items (1.0.0) | User Manager (1.5.0) | comprofiler (1. | Content Page (1.5.0) | Akeeba (3.4.3) | uddeim (2.4) | Mass Mail (1.5.0) |
Modules :: SITE :: RokMiniEvents (1.5) | AJAX Shoutbox (1.4) | RokTabs (1.19) | Search (1.0.0) | Login (1.5.0) | Latest News (1.5.0) | RokFeatureTable (1.1) | CB Login (1.7) | Statistics (1.5.0) | Banner (1.5.0) | CB Workflows (1.7) | RokStories (2.2) | Feed Display (1.5.0) | Menu (1.5.0) | Archived Content (1.5.0) | RokContentRotator (1.5) | Ninjaboard Quickpanel (1.1.0) | Random Image (1.5.0) | Kunena Latest (1.7.0) | Newsflash (1.5.0) | Footer (1.5.0) | RokNewsPager (1. | RokTwittie (2.3) | uddeIM Notifier (2.4) | uddeIM Notifier (2.4) | Wrapper (1.0.0) | Syndicate (1.5.0) | RokNavMenu (2.11) | Sections (1.5.0) | Custom HTML (1.5.0) | Breadcrumbs (1.5.0) | Related Items (1.0.0) | Most Read Content (1.5.0) | Who\'s Online (1.0.0) | Poll (1.5.0) |
Modules :: ADMIN :: Admin Submenu (1.0.0) | Login Form (1.0.0) | Admin Menu (1.0.0) | Quick Icons (1.0.0) | Latest News (1.0.0) | Title (1.0.0) | Items Stats (1.0.0) | Toolbar (1.0.0) | Unread Items (1.0.0) | Feed Display (1.5.0) | Logged in Users (1.0.0) | Footer (1.0.0) | User Status (1.5.0) | Akeeba Backup Notification Mod (3.4.3) | Custom HTML (1.5.0) | Online Users (1.0.0) | Admin Tools Joomla! Upgrade No (svn385) | Popular Items (1.0.0) |
Plugins :: SITE :: XML-RPC - Blogger API (1.0) | XML-RPC - Joomla API (1.0) | RokNavMenu - Boost (2.11) | RokNavMenu - Extended Link (2.11) | User - Example (1.0) | User - Joomla! (1.5) | Search - Categories (1.5) | Search - Content (1.5) | Search - Newsfeeds (1.5) | Search - Weblinks (1.5) | Search - Ninjaboard (1.0) | Search - Sections (1.5) | Search - Contacts (1.5) | Editor - TinyMCE 3 (3.2.6) | Editor - RokPad (1.7.2) | Editor - XStandard Lite for Jo (1.0) | Editor - JCE (2.0.12) | Authentication - GMail (1.5) | Authentication - LDAP (1.5) | Authentication - Example (1.5) | Authentication - Joomla (1.5) | Authentication - OpenID (1.5) | Button - Readmore (1.5) | Button - Image (1.0.0) | Button - RokCandy (1.4) | Button - Pagebreak (1.5) | Content - Email Cloaking (1.5) | Content - Load Modules (1.5) | Content - Code Highlighter (Ge (1.5) | Content - Example (1.0) | Content - Vote (1.5) | Content - RokBox (1. | Content - Page Navigation (1.5) | Content - Pagebreak (1.5) | System - Registration Validato (1.3.0) | System - Cache (1.5) | System - One Click Action (1.0) | System - jSecure Authenticatio (2.1.2) | System - Ninja Framework (1.5.0) | System - Mootools Upgrade (1.5) | System - Akeeba Backup Update (1.0) | System - RokCandy (1.4) | System - Debug (1.5) | System - Koowa (0.7.0) | System - Remember Me (1.5) | System - Kunena (1.7.0) | System - System Restore Points (3.3.4) | System - RokGantry Cache (1.0) | System - RokBox (2.6) | System - Log (1.5) | System - Legacy (1.5) | System - RokGZipper (1.12) | System - Admin Tools (2.1.6) | System - Backlinks (1.5) | System - SEF (1.5) | Akeeba Backup Lazy Scheduling (3.3) |Templates Discovered :: wrote: Templates :: SITE :: JA_Purity (1.2.0) | rhuk_milkyway (1.0.2) | rt_nebulae_j15 (1.5.0) | beez (1.0.0) |
Templates :: ADMIN :: Khepri (1.0) |
Thanks for the reply sozzled and here is the report you requested.
I am aware that 777 chmod is unnecessary but I have changed it just to see if they were permission issues as mentioned previously.
First of all, never use CHMOD 777 on a Joomla site. Read Securing Kunena
The problem is not caused by wrong file permissions anyway. The problems are being caused by all that Rockettheme stuff that you have loaded on your site, especially that RokGZipper plugin that has been the source of many problems people have with Kunena.
I would be willing to bet any money you like that if you tried the approach in When all else fails, try this . Yours is a classic case of Which came first? The template or the forum?
Your task should be to install K 1.7.2 (don't mess around with K 1.7.0 which is not supported anyway) and to use the updated language pack for K 1.7.2 (available from the download page). To do that, you need to remove, one by one, each plugin that is interfering with successfully allowing you to upgrade Kunena. Start with all the Rockettheme plugins first and see how you go; if they weren't causing the problem, then work your way further until you find the culprit.
I like the output generated by Forum Post Assistant, by the way. It's missing one or two things that are included in the Kunena forum configuration report , but it certainly saves a lot of time asking you, "What else have you installed that might be interfering?"
- devilstormz
- Topic Author
I would love to upgrade to the latest version too
I have to agree with you on some of the conflicts with rockettheme templates and kunena as I did experience with the Board code not appearing and was caused by rokbox plugin.
FYI RokCandy is a bigger cause of BBcode problems!devilstormz wrote: I have to agree with you on some of the conflicts with rockettheme templates and kunena as I did experience with the Board code not appearing and was caused by rokbox plugin.
