Question 1.5.14 upgrade issue
13 years 2 months ago #1 by kmilos
1.5.14 upgrade issue was created by kmilos
I have just tried upgrading to 1.5.14 from 1.5.13 (without uninstalling) and got an "XML error on 3:84", which is I presume because of the non-ASCII character in kunena.install.upgrade.xml
The result is "Upgrading Kunena to version 1.5.14 has failed!" at the top when I go to the component control panel, and "Installed version: Kunena 1.5.14 | 2010-11-04 | 1902 [ NOT UPGRADED ]..." at the bottom.
The following user(s) said Thank You: nguoiveday
13 years 2 months ago #2 by testeuse
Replied by testeuse on topic Re: 1.5.14 upgrade issue
Hi, I have the exact same issue with kunena 1.5.14, i am trying to upgrade to 1.5.14 from 1.5.13 but it give me the same errors than Kmilos :
"XML error on 3:84" and "Installed version: Kunena 1.5.14 | 2010-11-04 | 1902 [ NOT UPGRADED ]..." at the bottom.
What can i do please? I can't use 1.6 because my editor is not showing in 1.6.
Please help !!
13 years 2 months ago #3 by fxstein
Replied by fxstein on topic Re: 1.5.14 upgrade issue
What php version are you guys running on?
13 years 2 months ago #4 by 810
Replied by 810 on topic Re: 1.5.14 upgrade issue
Hi, there seems to be a name conflict.
Try this:
manifest.xml line 5
<versionname>Comunità (Italian for: Community)</versionname>
change to:
<versionname>Comunita</versionname>
Regards 810
The following user(s) said Thank You: C.A.M
13 years 2 months ago #5 by kmilos
Replied by kmilos on topic Re: 1.5.14 upgrade issue
@fxstein
PHP Built on: Linux xyz 2.6.32-22-server #36-Ubuntu SMP Thu Jun 3 20:38:33 UTC 2010 x86_64
Database Version: 5.0.51a-3ubuntu5.4
Database Collation: utf8_general_ci
PHP Version: 5.2.4-2ubuntu5.7
Web Server: Apache
Web Server to PHP interface: apache2handler
Joomla! Version: Joomla! 1.5.22 Stable [ senu takaa ama woi ] 04-November-2010 18:00 GMT
@810
Thanks, I figured already it's a name conflict. But then what? Try upgrade again? Uninstall/reinstall? Will it mess up my setup? I'd rather wait for an official and tested fix.
13 years 2 months ago #6 by 810
hi, we have tested this. the fix will be in the next release. Its only a name error, so no setup setting/database settings will be lost.
1) Edit the manifest.xml in the package
2) Run update again, then the problem is gone.
13 years 2 months ago - 13 years 2 months ago #7 by Scottux
Replied by Scottux on topic Re: 1.5.14 upgrade issue
kmilos wrote: Thanks, I figured already it's a name conflict. But then what? Try upgrade again? Uninstall/reinstall? Will it mess up my setup? I'd rather wait for an official and tested fix.
Hello :)
Now, upgrading is OK for me with these modifications :
In file named manifest.xml :
Line 5, replace
with
In file named kunena.install.upgrade.xml :
Line 3 and line 348, replace
"Comunitˆ (Italian for: Community)"
with
"Comunita"
Last edit: 13 years 2 months ago by Scottux.
The following user(s) said Thank You: kmilos, C.A.M, robytotem
13 years 2 months ago #8 by kmilos
@Scottux, @810
Yep, editing only manifest.xml is not enough (at least not after the build is done.)
For a long term solution maybe adding
encoding="utf-8"
to the /trunk/1.5/administrator/components/com_kunena/install/kunena.install.upgrade.xml template would be best?
13 years 2 months ago #9 by treehugger
Replied by treehugger on topic Re: 1.5.14 upgrade issue
This worked a treat - thank you.
13 years 2 months ago #10 by kmilos
Btw, this can also impact K1.6 and future K2.0 too, as reported:
joomlacode.org/gf/project/kunena/tracker...racker_item_id=24742
Time to create page: 0.536 seconds
