- Thank you received: 4
Kunena 6.2.6 released
Question Kunena Discuss 3.0 Plugin does not allow guests to be the first to post article comments.
Has there been any update on the Kunena developers for the GitHub fix for the Kunena Discuss plugin bug that prevents Guests from posting first in article comments?
I have the latest version Kunena Discuss 3.1.1 and it's still not allowing Guests to post first topic/reply.
Thanks for any help on how to fix this.
not logged in (so guest), place comment, topic for article is created and comment is posted as reaction.
probably it works for me because I do not use Joomla caching? (I do use Kunena caching)
sharing = caring
I must admit that I have not followed the progress of this topic for the two years that it has been running. I posted a topic about Joomla caching, guest posting and Kunena Discuss a couple of months ago and, like this topic, it was not addressed by the developers.ruud wrote: Just tested and I do not have this issue ... [probably] works for me because I do not use Joomla caching? (I do use Kunena caching)
You may have hit upon the reason why Kunena Discuss does not allow guests to be the first to post comments. In actual fact, if you have Joomla caching turned on, guests may not be able to post comments at all. I'm not sure about this and the developers do not seem to know the answer either.
EDIT: Message #2 (which appeared 2 years ago) explains the reason and proposed a way to resolve the problem. Matias (the original developer of Kunena Discuss who is no longer actively involved in the project) wrote that he would "look into it".
The cause of the problem and the short answer to the question is, if you want guests to use Kunena Discuss to post comments about articles, you need to disable Joomla caching on your website.
