- Thank you received: 1434
Please Read This First:
This category is only for reporting defects with K 3.0.
Do not use this category:
- to ask general questions about how to use K 3.0 or to ask when new versions of Kunena will be released;
- to ask about other (older) versions of Kunena; or
- if you have tried to install K 3.0 on J! 1.5; or
- if you installed K 3.0 on a live, production site and you want your site restored to its previous state; or
- if this website ( www.kunena.org ) works but works differently to how you expected.
You must include your K 3.0 configuration report; if you do not include your configuration report, your topic may be closed (locked) or deleted without any further warnings from the moderators.
Topics that have been closed (resolved) will be archived and no further discussion on those topics will be allowed.
Question Page does not reload after sending a post
Thanks for further help!
Thanks in advance!
Copy joomla files
Then import the database
setup the configuration.php on the root (to access database/website)
Install kunena.
Check if its working.
If working, then install your other components/plugins one by one. until its broken. Then you know where the issue is.
If not working, then there is a issue with database or server setting
First I started to switch off the Option "Activate Access Control" (or so, I have the german version) in the Kunena - Joomla Integration Plug-In.
Result: It worked for all forums, but only the members with "Moderation" - Access Level could see the forums. So I found out that it must have to do something with the access-control of Kunena. But with switched off the Option Access Control in the "Kunena - Joomla Integration" Plug-In there was no way to give access to my registred users to the forums.
Then I switched on the access control again and while trying I made a new forum and see: everything worked without problems in this new forum. But in the old forums I had the same problem again (not switching to the post after sending the post), and they have exactly the same settings...!
So it means: For new forums everything works well. For existing forums the error appears as sson as I activate the option access control in the "Kunena - Joomla Integration" Plug-In. As soon as I deactivate this option it works but my users have no entry anymore to the forums.
I know I could now make new forums and move all existing posts in this forums. But I have hundreds of posts and they are referenced with the URL in other sections so I would cut that links. And I also have installed Kunena Latest Module for each of the 24 forums and would have to change them as well. Means many hours of work. And last but not least: the users have mail-subscriptions on the forums and would loose them all. To instruct them to subscribe again would make me loose some users.
Is there another thing which could solve this problem?
Thans for your further answer!
Best Regards
Chris
1) The topic talks about a "defect" in K 3.0. The developers stated over one month ago at the time of the release of K 4.0.5:
K 3.0 is no longer an active project and support for K 3.X will cease on 31 August 2015.
Therefore the category could be locked at any time and I would not be able to give you my thoughts.
2) I do not know if this is a defect with Kunena or a problem caused by using Community Builder. Evidently the developers and moderators have been unable to help you find the cause of the problem as well. There is a separate category where people can discuss problems they may have using Kunena with Community Builder.
In my opinion it may be better to move this topic to the Community Builder category. Of course I cannot move this topic for you (and you cannot move this topic yourself) but you can ask the moderators to move the topic for you.
I understand that some people will have difficulty using the Kunena - Community Builder integration plugin . I admit that I have not used Community Builder for some years and I am not well versed in answering questions about this component.
Access control can be particularly troublesome.
Some years ago, when there was no serious access control in J! 1.5, Community Builder provided a way for people to secure their forum categories. Since J! 1.6, there has been less need to rely on Community Builder's access control mechanism. Kunena relies on Joomla's ACL access control.
Some people believe they can use Community Builder instead of Joomla to control access to their website assets. I make no comment about that.
If you look at just about any of the posts I have written on this forum, I recommend the following forum integration settings (if you are using Community Builder) shown in red text below:
Kunena - Community Builder Enabled: access=0 login=0 activity=0 avatar=1 profile=1 private=0
You should also be using the latest version of Community Builder (version 2.0.10)
If you require help with Community Builder, perhaps the first place to start is with the good people at Joomlapolis
When you wrote that you were having problems with your "old [categories]", perhaps a good place to start is to look at the permissions for those categories with the Kunena Category Manager. When you say that these are "old [categories]", are they old because you migrated your website from J! 1.5? Perhaps some things were not properly finalised as part of that Joomla migration?
I do not think you will need to move topics from your "old [categories]" to the newer categories. I do not think you will need to have to ask your users to re-subscribe, either.
I will do the best I can help you but I believe I have given you a few things to think about as a start.
The first suggestion I would make is that you ask the forum moderators to move this topic to the Community Builder category and, that way, we will not lose the ability to keep giving you the help that you have asked for. The moderators will not move this topic because I have suggested it; the moderators here do not agree with most of my suggestions as to where topics should be located.
1) In the beginning of the problem I used K3 but I updated now to K4.05, where I still have this problem, so maybe the topic should be moved to Kunena 4.0 Support Forum
2) I have CB 2.0.10 installed and used exactly the same settings as you recommend
But even when I switch CB-Integration completly off it doesn't work, so it will be no CB-Issue. It seems to work with CB but I don't want to do the access control with CB.
The permissions for the old and new categories in the category manager are exactly the same.
The "old" forums have been migrated from 1.5 - you're rigth with that. But they worked without problems after the migration one year ago. I didn't changed anything at or just before that moment the problem occured. But I don't now if maybe the provider changed to a newer version of php. But this shouldn't be a problem or?
Best regards
Chris
If you want a response to a problem caused by K 4.0.5 then, by all means, have the topic moved into the "reporting defects" category and let the developers try to help you there.
If, as I suspect, the problem is caused by Community Builder then the "CB" category is better, in my opinion, and I may be able to assist you there.
I have studied this topic and the only configuration report I have seen is in the first post. Therefore, unless I saw an updated configuration report from you, I would only be guessing as to what you might try next.
I think it has to do with the access-right check, which Kunena performs. After this check and the sending of the post it stops somewhere and not forward the site after to the sent post out of some reason.
Here the configuration report (after I switched the CB-Plugin on for the avatar):
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: 120M | Max file upload: 40M
ID Name Menutype Link Path In trash 186 Forum kunenamenu view=home&defaultmenu=188 forum No 187 Kategorien kunenamenu view=category&layout=list forum/index No 188 Aktuell kunenamenu view=topics&layout=default&mode=replies forum/aktuell No 189 Neues Thema kunenamenu view=topic&layout=create forum/neuesthema No 190 Ohne Antwort kunenamenu view=topics&layout=default&mode=noreplies forum/ohneantwort No 191 Meine Themen kunenamenu view=topics&layout=user&mode=default forum/meinethemen No 192 Profil kunenamenu view=user forum/profil No 193 Regeln kunenamenu view=misc forum/regeln No 194 Hilfe kunenamenu view=misc forum/hilfe No 195 Suche kunenamenu view=search forum/suche No 132 Forum Intranet-Navigation option=com_kunena forum-132 No 488 Testforum Intranet-Navigation view=topic&layout=create&catid= testforum No
Joomla default template details : SustainCo-Intranet | author: Design72 | version: 2.5.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.5 | creationdate: 2015-08-17
Kunena version detailed: Kunena 4.0.5 | 2015-08-17 [ Turnau ]
Kunena config settings: board_offline 0 enablerss 1 threads_per_page 20 messages_per_page 50 messages_per_page_search 30 showhistory 1 historylimit 10 shownew 1 disemoticons 0 template blue_eagle showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 0 askemail 1 showemail 0 showuserstats 1 showkarma 0 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 1 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 300 imageheight 1200 imagewidth 1600 imagesize 3000 filetypes zip,txt,doc,gz,tgz,xls,docx,xpsx,ppt,pptx,pdf,xlsx filesize 3000 showranking 1 rankimages 1 userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_posts 1 userlist_karma 0 userlist_email 0 userlist_joindate 0 userlist_lastvisitdate 1 userlist_userhits 0 latestcategory 0 showstats 1 showwhoisonline 0 showgenstats 1 showpopuserstats 0 popusercount 5 showpopsubjectstats 1 popsubjectcount 10 showspoilertag 0 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 0 ebaylanguagecode en-us sessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 defaultpage recent default_sort asc sef 1 showimgforguest 1 showfileforguest 0 pollnboptions 7 pollallowvoteone 1 pollenabled 1 poppollscount 10 showpoppollstats 1 polltimebtvotes 10:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat datetime post_dateformat_hover ago hide_ip 1 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 100 thumbheight 80 thumbwidth 80 hideuserprofileinfo put_empty boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 debug 0 catsautosubscribed 0 showbannedreason 0 showthankyou 1 showpopthankyoustats 1 popthankscount 10 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 show_list_time 8760 show_session_type 1 show_session_starttime 0 userlist_allowed 1 userlist_count_users 3 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 0 thankyou_max 10 email_recipient_count 0 email_recipient_privacy bcc captcha_post_limit 0 keywords 0 userkeywords 0 image_upload registered file_upload registered topic_layout flat time_to_create_page 1 show_imgfiles_manage_profile 1 hold_newusers_posts 0 hold_guest_posts 0 attachment_limit 8 pickup_category 0 article_display intro send_emails 1 fallback_english 1 cache 1 cache_time 60 iptracking 1 rss_feedburner_url autolink 1 access_component 1 statslink_allowed 1 superadmin_userlist 0 legacy_urls 1 attachment_protection 0 categoryicons 1 avatarresizemethod 1 avatarcrop 0 user_report 1 searchtime 365 teaser 0 ebay_language 0 twitter_consumer_key twitter_consumer_secret max_links 6 userlist_name 1 usernamechange 0 version_check 1 userlist_usertype 0 sefutf8 0 enablepdf 1 jmambot 0 annmodid 62 changename 0 userlist_username 0 rules_infb 1 help_infb 1 onlineusers 1 | Joomla! detailed language files installed:Warning: Spoiler!Kunena - AlphaUserPoints Disabled
Kunena - Community Builder Enabled: access=0 login=0 activity=0 avatar=1 profile=0 private=0
Kunena - Kunena Enabled: avatar=0 profile=1
Third-party components: CommunityBuilder 1.9.1 | UddeIM 3.7
Plugins: None
Modules: Kunena Latest 3.1.1
