- Thank you received: 5
Question Help with Diagnostics
userReadOrphaned TEST FAILED 3993 issues DELETE BROKEN ITEMS
userReadWrongCategory TEST FAILED 11035 issues FIX ISSUES
userTopicOrphaned TEST FAILED 20 issues DELETE BROKEN ITEMS
channelOrphaned TEST FAILED 12 issues FIX ISSUES
what will happen with each one if i click to fix or delete?
I dont want to delete any posts or attachments, what is each of these?
userReadOrphaned userReadWrongCategory userTopicOrphaned channelOrphaned
Thank you
like
userReadOrphaned = Looks if the topic still exists, you will get this issue, when you permadelete topics
userReadWrongCategory = Looks if the category still excists
userTopicOrphaned = Looks if the topic still exists
channelOrphaned = categories that have a missing channels.
You can delete the items, But backup before. Its removing data.
userReadOrphaned TEST FAILED 4035 issues DELETE BROKEN ITEMS
userReadWrongCategory TEST FAILED 18027 issues FIX ISSUES
with delete broken items i will loose online posts ?
what will happen with FIX ISSUES ?
The fix button remove orphaned data in the database and/or also messages without sections/categories. Perhaps it fixes the error from this topic. www.kunena.org/forum/general-questions-a...problem-with-a-topicwhat will happen with FIX ISSUES ?
But it is important, to create a backup before you use the fix button!
So i know what i am removing ?
