Kunena 6.2.6 released
Solved Installation Issue. Never had this problem before
- jcraft1013
- Topic Author
7 years 8 months ago #1
by jcraft1013
Installation Issue. Never had this problem before was created by jcraft1013
I've put Kunena on two other websites I manage, but this is the first time I've had an issue. First, I installed 5.0.. got errors. So i tried Installing 4.0. Similar errors. So I left 4.0 files on there and tried to upgrade.
Here's 5.0 errors:
Kunena Installation Failed!
Sorry, installation failed with following error:
Warning: DOMDocument::load(): I/O warning : failed to load external entity "/home1/jcraft/public_html/ethiopianrpi.com/administrator/KPATH_ADMIN/install/install.xml" in /home1/jcraft/public_html/ethiopianrpi.com/administrator/components/com_kunena/install/schema.php on line 363
Warning: Invalid argument supplied for foreach() in /home1/jcraft/public_html/ethiopianrpi.com/administrator/components/com_kunena/install/schema.php on line 529
Fatal error: Class 'KunenaRoute' not found in /home1/jcraft/public_html/ethiopianrpi.com/administrator/components/com_kunena/install/sql/install/php/sampledata.php on line 159
Got similar errors installing 4.0. So after I decided to install 5.0 leaving 4.0 files there, I got:
Warning
Table 'jcraft_jmln6.#__kunena_categories' doesn't exist SQL=UPDATE `#__kunena_categories` SET iconset='default' WHERE iconset='system'
Package Update: There was an error installing an extension: com_kunena_v5.0.0.zip
Error
Error installing package
Can anyone assist please? I'm not an advanced developer. Sort of intermediate. Thanks!
Here's 5.0 errors:
Warning
Error
7 years 8 months ago - 7 years 8 months ago #2
by 810
Replied by 810 on topic Installation Issue. Never had this problem before
yes, this is a common installation error.
Please clean cache on frontend and backend site. then run the package again
Last edit: 7 years 8 months ago by 810.
7 years 8 months ago #3
by RN3ANT
Replied by RN3ANT on topic Installation Issue. Never had this problem before
The same problem with version 4 and now with version 5. It is impossible to install Kunena no one way.
Advice to clean cache does not help. Tryings to install are crashed each time.
- jcraft1013
- Topic Author
7 years 8 months ago #4
by jcraft1013
Replied by jcraft1013 on topic Installation Issue. Never had this problem before
My issue is fixed. Never had an issue before. And now it is perfect
7 years 8 months ago #5
by RN3ANT
All cache are cleaned. The only table in base, smth, like xxx_kunena-version — deleted. All kunena related catalogues removed in whole everywhere in Joomla.
Result = 0. The same error
jcraft1013 wrote: My issue is fixed…
7 years 8 months ago #6
by 810
@RN3ANT please create a new topic, then I will help you
Time to create page: 0.362 seconds
