- Thank you received: 1
Solved Strange installation problem
7 years 7 months ago #1
by dimoss
Strange installation problem was created by dimoss
Hi
I am trying to install the latest Kunena on a J!2.5.28.
Unfortunately the installation stop and I get error 500 before the installation popup open and continue with the rest.
I enabled the debug to Maximum and when I returned I got these errors:
Sorry, installation failed with following error:
Notice: Use of undefined constant KPATH_ADMIN - assumed 'KPATH_ADMIN' in /opt/lampp/htdocs/pdan/administrator/components/com_kunena/install/schema.php on line 13
Notice: Use of undefined constant KPATH_ADMIN - assumed 'KPATH_ADMIN' in /opt/lampp/htdocs/pdan/administrator/components/com_kunena/install/schema.php on line 14
Notice: Trying to get property of non-object in /opt/lampp/htdocs/pdan/administrator/components/com_kunena/install/schema.php on line 401
Warning: Invalid argument supplied for foreach() in /opt/lampp/htdocs/pdan/administrator/components/com_kunena/install/schema.php on line 422
Fatal error: Class 'KunenaRoute' not found in /opt/lampp/htdocs/pdan/administrator/components/com_kunena/install/sql/install/php/sampledata.php on line 147
I am at a loss because when I tried to another J!2.5.28 it worked like a charm.
I also tried in a clean installation and again worked like a charm.
Can u help me pls?
Thanks!
Can u help me pls?
Thanks!
7 years 7 months ago #2
by rich
Replied by rich on topic Strange installation problem
Clear the Joomla cache and try it again.
7 years 7 months ago #3
by dimoss
Replied by dimoss on topic Strange installation problem
Solution found..
I have Fabrik installed.
I had to disable Fabrik system plugin and move it on top of the order before I install Kunena.
I did it and the installation done!!
P.S. I share it just in case someone else has the same problem
7 years 7 months ago #4
by rich
Thank you!
Thank you!
Time to create page: 0.344 seconds
