Solved Vertical editor symbols and menu translation
7 years 9 months ago #1
by Comraw
Vertical editor symbols and menu translation was created by Comraw
the next Problems have already come up.
These are two separate problems but I didn't want to flood the forum.
The first problem is this:
imgur.com/2RP2PaJ
How do i get the symbols to horizontal?
The second problem is this:
imgur.com/L2ApVdY
The main navigation bar is in German, the rest is in English. How do I get the navigation to become English, too?
Cheers,
Comraw
imgur.com/2RP2PaJ
imgur.com/L2ApVdY
Cheers,
Comraw
7 years 9 months ago #2
by rich
For your first question we need a account as registered user so we can see the problem.
The menu items can easily be edited by using the Joomla Menu Manager "Menus -> Kunena Menu -> Menu Item ->To alter the Menu Title".
www.kunena.org/docs/en/faq/kunena-menu
Replied by rich on topic Vertical editor symbols and menu translation
It's better no various questions in a topic.These are two separate problems but I didn't want to flood the forum.
The following user(s) said Thank You: Comraw
7 years 9 months ago #3
by Comraw
Replied by Comraw on topic Vertical editor symbols and menu translation
Hi rich,
thank you for your answer. The trick with the menus worked perfectly, thank you.
To test the other problem I have created a test user for you:
Username: Testuser
Password: test
Login here peerandpeer.de/index.php then click on "Forum" in the top navigation.
Access any category and create a new thread.
Cheers,
Comraw
Username: Testuser
Password: test
Cheers,
Comraw
7 years 9 months ago - 7 years 9 months ago #4
Replied by sozzled on topic Vertical editor symbols
Try this CSS rule:Comraw wrote: How do i get the symbols to horizontal?
tr#kpost-topicicons > td.kcol-mid > span, div#smilie {
display: inline-flex;
Last edit: 7 years 9 months ago by sozzled. Reason: Minor change in subject
7 years 9 months ago - 7 years 9 months ago #5
by Comraw
Hey sozzled,
thank you very much, that did the trick. Both problems are now solved.
Last edit: 7 years 9 months ago by Comraw.
Time to create page: 0.337 seconds
