Solved Kunena to import on a clean install
Grazie
Hi, unfortunately I upgraded Joomla version 2.x to 3.x motissimi I had problems, I wanted to do a clean install of Joomal and all the various components and plugins including forums Kunema, let me know how I can save the entire contents of the forum then reinstate
I point out that the site and went completely offline and can not access the menu admin Joomla, how can I save the contents of my forum and put it back after you reinstall everything?
Thank you
1. Create a complete backup
2. Export all Kunena tables from your old installation
3. Export all Joomla user tables from your old installation
4. Copy the folder kunena "root/media/kunena" (he contains avatars and attachments)
5. Install Joomla 3.x
6. Create again a backup
7. Import all kunena tables and the Joomla user tables in your new Joomla installation
8. Change the prefixes (the same as in the new installation)
9. Check in backend "Extensions -> Manage -> Database" if everything is correct
10. Install Kunena
I'll let you know
P.S
I have not imported the backup and a clean install
Problem with the backup I imported backup tables but gives me this error means what? here is the screenschot
Query SQL: Documentazione
-- Database: `Sql666197_1`
DELIMITER $$--
-- Procedure
CREATE DEFINER = `Sql666197`@`%` PROCEDURE `n73x8_TeraWurfl_FallBackDevices` ( current_fall_back VARCHAR( 64 ) ) BEGIN find_fallback : WHILE current_fall_back != 'root' DO SELECT capabilities
FROM n73x8_TeraWurflMerge
WHERE deviceID = current_fall_back;
IF FOUND_ROWS( ) =0 THEN LEAVE find_fallback;
END IF ;
SELECT fall_back
INTO current_fall_back;
END WHILE;
END$$
Messaggio di MySQL: Documentazione
#1304 - PROCEDURE n73x8_TeraWurfl_FallBackDevices already exists
You should import only all kunena tables and the Joomla user tables. Not he complete backup.
I installed Joomla 3, without kunema tables, user tables were empty, the area code and the same, the amount by the panel file msql finishes loading and you see me error
