Solved Buttons too long and forum posts going off screen
9 years 2 months ago - 9 years 2 months ago #1 by ChrisL
Hi
I recently upgraded from 1.6 Joomla to 3.3.6 and also Kunena latest version from what was being run on 1.6.
Iv noticed that the buttons have become very long for things like topic reply and also the forum posts are disappearing off screen at the right hand side. Both these problems only happen when a user is logged in.
Here is an example:
www.aberdeensnooker.co.uk/index.php/forum/14/12088#12105
Any ideas how I sort this please?
Last edit: 9 years 2 months ago by ChrisL.
9 years 2 months ago #2 by sozzled
9 years 2 months ago - 9 years 2 months ago #3 by ChrisL
That doesn't really help me. My buttons are displaying when logged in for example COM_KUNENA_BUTTON_TOPIC_REPLY instead of the usual Topic Reply. This wasn't the case before. But has happened since updating joomla and kunena for 3.3.6. Any ideas how to change the buttons back to normal first of all? I am using the basic Beez2 template by the way.
Configuration Report
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : beez_20 | author: Angie Radtke | version: 2.5.0 | creationdate: Unknown
Kunena version detailed: Kunena 3.0.7 | 2015-02-01 [ Galah ]
Third-party components: UddeIM 3.5
Plugins: None
9 years 2 months ago #4 by rich
You use the old Kunena template 1.6.4. Go in backend to "Kunena > Templates" and choose the template Blue Eagle 3.0.7.
The following user(s) said Thank You: ChrisL
9 years 2 months ago #5 by ChrisL
Yes only just figured that out I just made the new one the default and formatting sorted!
Time to create page: 0.554 seconds
