Kunena 6.2.6 released
Question Installation fail due to "copy failed"
8 years 11 months ago - 8 years 11 months ago #1
by photokev
Installation fail due to "copy failed" was created by photokev
Hi everyone,
I've installed Kunena many times in the past with no issues and this one has me stumped.
Here's the scenario:
Attempted installing by URL, uploading installer and from my temp directory, all with the same results, an error saying the following:
Warning
Copy failed.
JInstaller: :Install: Failed to copy file /var/www/vhosts/blueplanetps.com/astropartsoutlet.com/tmp/install_553881a99f677/pkg_kunena.xml to /var/www/vhosts/blueplanetps.com/astropartsoutlet.com/administrator/manifests/packages/pkg_kunena.xml
Package Install: Could not copy setup file.
Error
Error installing package
Here's the tech setup
The "manifest" directory is set to 755
System Information
Setting Value
PHP Built On Linux plesk2.websitesource.com 2.6.32-504.3.3.el6.x86_64 #1 SMP Wed Dec 17 01:55:02 UTC 2014 x86_64
Database Version 5.1.73
Database Collation utf8_general_ci
PHP Version 5.4.16
Web Server Apache
WebServer to PHP Interface cgi-fcgi
Joomla! Version Joomla! 3.4.1 Stable [ Ember ] 21-March-2015 20:30 GMT
Joomla! Platform Version Joomla Platform 13.1.0 Stable [ Curiosity ] 24-Apr-2013 00:00 GMT
User Agent Mozilla/5.0 (Macintosh; Intel Mac OS X 10.7; rv:37.0) Gecko/20100101 Firefox/37.0
I've tried installing various versions of V3.X of Kunena
The component name shows up in the component menu but when you click on it the progress bar only goes about a milimeter and you get an instillation fail alert
Any ideas?
Thanks!
Warning
Copy failed.
Error
System Information
Setting Value
PHP Version 5.4.16
Web Server Apache
Any ideas?
Thanks!
Last edit: 8 years 11 months ago by photokev.
8 years 11 months ago #2
by rich
Replied by rich on topic Installation fail due to "copy failed"
It could be a problem with the rights. The following folders need to have write permissions:
/administrator/components
/components
/libraries
/tmp
/logs
/media
/plugins
/plugins/system
/plugins/quickicon
You can check it in the backend "System > Sysem Information > (tab) Directory Permissions".
/components
/libraries
/tmp
/logs
/media
/plugins
/plugins/system
/plugins/quickicon
The following user(s) said Thank You: photokev
8 years 11 months ago #3
by photokev
Replied by photokev on topic Installation fail due to "copy failed"
Is there a way to manually install it?
8 years 11 months ago #4
by photokev
I'll check those permissions. If it were permissions, would it make sense that I can install other components but not Kunena though?
8 years 11 months ago #5
by photokev
Hi Rich,
I took a look at the permissions and they're all writable.
Time to create page: 0.379 seconds
