Kunena 6.2.6 released
Solved Blank page for dashboard
9 years 2 weeks ago - 9 years 2 weeks ago #1 by Murnane
After instaling kunena I get a blank page when I click Dashboard or any other Kunena Forum link under Components
If I install by URL I get the following errors
Warning
Error connecting to the server: SSL certificate problem: unable to get local issuer certificate
Error
Invalid URL
Unable to find install package
And then when I install by upload package file (uploading: com_kunena_v3.0.7.zip)
I get a success message
Message
Installing component was successful.
but blank pages for any of the Kunena Forum link under Components
I'm trying these installations on a new install of Joomla that has a fresh install of Jomsocial on it.
Any help would be appreciated
I'm a total newbie here so please forgive me if I've messed up on forum protocol
Regards James
Last edit: 9 years 2 weeks ago by xillibit. Reason: Add confidential tag
9 years 2 weeks ago #2 by xillibit
Replied by xillibit on topic Blank page for dashboard
Hello and welcome,
Can-you set into your Joomla! configuration panel the error reporting on maximum and check after that if you have still blank page when you try to access Kunena component. Instead the blank page you should see an error message.
9 years 2 weeks ago #3 by Murnane
Replied by Murnane on topic Blank page for dashboard
Thanks xillibit
Did what you said and get the following error when going to dashboard
Fatal error: Class 'KunenaForum' not found in /var/www/vhosts/26/324532/webspace/httpdocs/example.com/administrator/components/com_kunena/install/model.php on line 1349
And thanks for the welcome :)
9 years 2 weeks ago #4 by xillibit
Try to check if the plugin Kunena system is right enabled
9 years 2 weeks ago #5 by Murnane
This might be where my newbieness shows :blush:
If I do a search for Kunena under Plugin manager I get:
There are no plugins installed matching your query.
Was I supposed to install plugins at the same time as com_kunena_v3.0.7.zip ?
9 years 2 weeks ago #6 by 810
Replied by 810 on topic Blank page for dashboard
its on the joomla plugin manager.
9 years 2 weeks ago #7 by Murnane
But if I go to the Plugin Manager page and search for Kuneau I get this
Was I supposed to install plugins at the same time as I installed com_kunena_v3.0.7.zip ?
9 years 2 weeks ago #8 by 810
go to system - system information and check if all dir are writable, I think the plugins dir isn't writable, so the plugins aren't installed.
9 years 2 weeks ago #9 by Murnane
810 wrote: go to system - system information and check if all dir are writable, I think the plugins dir isn't writable, so the plugins aren't installed.
I did that and found that configuration.php was not writable.
I logged on via ftp and changed the file to 755
I tried to uninstall Kunena and reinstall it.
Same result, Blank page for dashboard and any other Kunena links
There must be something simple I'm missing on the installation process
For my install I go to Extensions > Extension Manager > Upload Package File
Then I browse to find com_kunena_v3.0.7.zip
I press Uplaod &Install and I get to a page that says
Message
Then I just get blank pages for Kunena pages
Am I missing a step?
9 years 2 weeks ago #10 by Murnane
Ok its working now :)
It seems I was forgetting to install the rest of the package
Silly me
Time to create page: 0.373 seconds
