Kunena 6.2.6 released
Solved K 3.0.6 + J! 3.3.6: "Installation failed"
From a fresh install of the latest version of Joomla, Kunena will not install. It installs some of the components (or all of them) and then it just says "Installation failed". Kunena shows up in the admin menu but clicking through to it gives me a similar screen where it just says "Installation failed". There's no error messages even with error reporting set to full and nothing shows up in the PHP error logs. Basically I'm not sure what the issue is. I think I found other posts in this forum detailing people having similar issues but no actual answers or solutions that seemed to apply.
Anyone have any ideas or know when this will be fixed? I want to use Kunena but there hasn't been an official update/release since July and Joomla recommends people upgrade to the latest version of Joomla (3.3.6) for security reasons and other things, which has been out for a few months now.
Joomla has had problems since J! 3.3.4—J! 3.3.5 and J! 3.3.6 have not fixed those problems. Even though Joomla "recommends" using J! 3.3.6, it may be better to use J! 3.3.3.zevious wrote: ... Joomla recommends people upgrade to the latest version of Joomla (3.3.6) for security reasons and other things, which has been out for a few months now.
I'm not sure what's broken about Joomla, but it seems like a workaround from Kunena could have been put out in the past few months. Every other component I use installs fine so it's something specific to the way Kunena does things.
1) download the package on the download page, then install kunena on the joomla installer.
2) copy the download link, and paste it on install from url. (joomla installer)
3) install it true the web installer.
BTW:
/administrator/index.php?option=com_kunena&view=install&task=run&i2bbmjao
Is the file it's trying to run after the Joomla install finishes, and I don't know if that's the issue or what but it's the last file I see in the inspector. (the token after the ampersand changes after each reload). I'm not getting any Javascript errors or any errors at all showing in the Chrome inspector.
Should be pretty easy to replicate, as well, just download Joomla 3.3.6 and try to install Kunena on it.
regards 810
