Kunena 6.2.6 released
Solved SQL error when trying to submit a new post to a migrated Kunena 3.0.6
9 years 7 months ago #1 by Jonty83
I recently updated my homepage from Joomla 1.5 to the latest relase. For this purpose I installed a complete fresh latest Joomla version and installed Kunena 3.0.6 and CB 1.9.1
I updated on the old hompage to Kunena 2.0.4 to have the same SQL database structure. Then I copied all tables from the old database into the new database (also migrating all users and CB 1.9.1).
I see all forum posts and categories as well as users.
When I try to submit a new post somewhere I get the following error message:
#1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ' 'test')' at line 1 SQL=INSERT INTO jo3_kunena_messages_text (mesid, message) VALUES (, 'test')
MySQL version: 5.5.31
The Kunena configuration report is:
Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 92M | Max file upload: 38M
Joomla default template details : beez3 | author: Angie Radtke | version: 3.1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Third-party components: CommunityBuilder 1.9.1 | UddeIM 3.4
Plugins: None
Thank you,
Christian
9 years 7 months ago #2 by Jonty83
I uninstalled Kunena, removed all tables from the database, reinstalled Kunena and moved every table manually. Now it works...
Time to create page: 0.364 seconds
