Solved Kunena 3.0.6 update fails - Update path does not exist
For now 3.1 is still under developpement and doesn't exists in beta package, 3.1 is intented for testers and developperslbrown wrote: I was having the same issue. Direct install from the url worked for me. I'm also having trouble trying to install 3.1 beta on this same server. No luck so far.
xillibit wrote: For now 3.1 is still under developpement and doesn't exists in beta package, 3.1 is intented for testers and developpers
This is correct (and it is a different issue to the one that others are discussing here).
It is necessary to build an installation package before you can install K 3.1. It is possible to download and copy the files you can find on GitHub but, to assemble K 3.1 in its entirety, you need to construct an installation package. There is no installation package for K 3.1 at GitHub. Only the files that are needed to build an installation kit are available at GitHub. Furthermore, there is no support for K 3.1 at this time while K 3.1 is still in alpha testing. Beta versions of software are also not supported - no-one (no software developer, that is) offers full support for beta versions of software.
For people who are having problems installing K 3.0.6, we strongly recommend that people use either the "automatic upgrade" (if you already have an older version of Kunena on your J! 3.x site) or you should use the "install by URL method" described in K 3.0 Installation Guide in the Wiki. Both the "automatic upgrade" and "install from URL method" have been thoroughly tested and work in the majority of cases. I have upgraded K 3.0.6 on about 5 websites (using both methods) and I have not had any problems.
People can have problems installing or upgrading to K 3.0.6 for several reasons. Most of the problems that people have in trying to install or upgrade to K 3.0.6 are network or server-related issues and that is why it's important to read the release notes , technical requirements and the installation or upgrade guides beforehand. Sometimes, it's simply a case of repeating the installation/upgrade process a second time to complete the installation. Sometimes you need to check if your Joomla installation is "different", "non-standard" or does not meet the technical needs.
There's no general one-size-fits-all solution. Each case can be different.
I hope this helps.
Warning
Error connecting to the server: 902
so am presuming issue is not Kunena but the joomla extension server?
- zydanielson
Kunena Forum | Update | Package 3.0.6 | N/A | Site update.kunena.org/3.0/pkg_kunena.xml
When I check the box and say Update, I get the following:
Warning
Error
Package download failed: joomlacode.org/gf/download/frsrelease/19...3.0.6_2014-07-28.zip
And one further question. People in this thread talk about installing from the URL. Does this mean I install Kunena as if I didn't have the extension and without uninstalling the Kunena I presently have? If so, I want someone's assurance that I won't lose anything in my forum. Far too much work has gone into it's creation, and far too much participation is there for me to start over.
My configuration report:
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 64M
ID Name Menutype Link Path 573 Forum mainmenu Itemid=564 kunena-2014-04-02 564 Forum kunenamenu view=home&defaultmenu=566 forum 565 Index kunenamenu view=category&layout=list forum/index 566 Recent Topics kunenamenu view=topics&mode=replies forum/recent 567 New Topic kunenamenu view=topic&layout=create forum/newtopic 568 No Replies kunenamenu view=topics&mode=noreplies forum/noreplies 569 My Topics kunenamenu view=topics&layout=user&mode=default forum/mylatest 570 Profile kunenamenu view=user forum/profile 571 Help kunenamenu view=misc forum/help 572 Search kunenamenu view=search forum/search
Joomla default template details : AS 002052 | author: AS Designing | version: 1.2.0 | creationdate: Unknown
Kunena config settings: board_offline 0 enablerss 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 12 shownew 1 disemoticons 0 template blue_eagle showannouncement 1 avataroncat 0 catimagepath category_images showchildcaticon 1 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 0 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 500 regonly 0 pubwrite 1 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatarupload 1 allowavatargallery 1 avatarquality 75 avatarsize 2048 imageheight 800 imagewidth 800 imagesize 150 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 120 showranking 0 rankimages 1 userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 0 userlist_posts 1 userlist_karma 0 userlist_email 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 2,3,8,9,11,16,17,13,14 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 0 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 showspoilertag 1 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 0 ebaylanguagecode en-us sessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 defaultpage recent default_sort asc sef 1 showimgforguest 1 showfileforguest 1 pollnboptions 10 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0 userlist_count_users 2 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 1 thankyou_max 10 email_recipient_count 0 email_recipient_privacy bcc captcha_post_limit 0 keywords 0 userkeywords 0 image_upload registered file_upload registered topic_layout flat time_to_create_page 0 show_imgfiles_manage_profile 1 hold_newusers_posts 0 hold_guest_posts 1 attachment_limit 8 pickup_category 0 article_display intro send_emails 1 fallback_english 1 cache 1 cache_time 60 iptracking 1 rss_feedburner_url autolink 1 access_component 1 statslink_allowed 1 | Joomla! detailed language files installed:Warning: Spoiler!Kunena - AlphaUserPoints Disabled
Third-party components: UddeIM 3.3
Plugins: None
"Life changes when you love what you love
more than you hate what you hate."
~ Elisha
If you want to try the latest github build, look into scripts/ as there are tools to symbolically link Kunena to your site. But that said, you really should only use that for testing, not for live sites!
Before using the git-link.sh or Windows version of it, you should have older version Kunena installed in your site. After linking you should also go to Kunena Torum > Tools > Git Install to update the database.
- zydanielson
Thank you. But I would still like confirmation about what installing from URL means, and:
- Do I uninstall Kunena before installing it again? If so, wouldn't that lose all I have configured and all the posting activity that is there?
- If uninstalling/reinstalling won't lose anything, I just want reassurance that it won't.
- Or, do I just install from URL without uninstalling what I presently have (3.0.5)?
I apologize for my nervousness. I have just never done what is being suggested here before. And there is a huge amount of work that I've done in configuration and that users have done in posting. I can't afford to lose that.
I'll do an Akeeba backup before, in any case. But I'd also rather not have to go through the restoration process. I just want to avoid doing something wrong and then having to spend a lot of time correcting it.
Thanks in advance,
Zy
~ Elisha
- coder4life
- Kunena Contributor
- Thank you received: 50
I will answer your questions one by one like you have so others can benefit. Let me know if you have any other questions. WARNING!: First and foremost, although we try our best to make sure installations are error free or the software can recover, we always recommend to BACKUP before doing any sort of installation. It is also important to note Installations Errors are usually related to Joomla and not Kunena as we utilize Joomla based installation procedures behind the scenes.
- You do not need to uninstall Kunena again, try to rerun the installer not from the Joomla Extension Update Manager and instead use the package here at kunena.org/download/ and upload it to the Joomla Extension Manager directly.
- Uninstalling instead of Reinstalling should not loose anything. We do not remove the database tables that are specific to Kunena or any user files upon Uninstalling Kunena (this is actually a problem for those that want to go clean slate on Kunena as they have remove the tables from database and and user folders manually). We did this on purpose because as you just witnessed Joomla does some weird stuff sometimes and sometimes we just need to reinstall the packages to make sure everything comes in cleanly.
- You can choose to use the two Joomla options in the backend, upload directly the downloaded package from our download page or right click and copy the download.
I fully understand the nervousness, we all been there at some point. The thing to take away from this is Reinstalling over the current package, or Uninstalling Kunena will not remove any data.
