Solved Fatal error: Class 'KunenaForum' not found in ../administrator/components/com_kunena/install/model.php on line 1345
PHP Version 5.3.27
Joomla! 3.1.5 Stable
Kunena last release download today
Fatal error: Class 'KunenaForum' not found in /home/vovaob/samsklepav.com/test/administrator/components/com_kunena/install/model.php on line 1345
Then install again, looks like a not overwriten file.
Regards 810
ps please disable captcha for registered user at support forum
Please check that the plugin System - Kunena is right enabled, if it disabled Kunena can't work correctly
xillibit wrote: Hello,
Now , I install and enable kunena system plg, result:
need to instull lib_kunena_v3.0.3
My joomla website is based on joomla 3.2.1 version and just installed kunena 3.0.4
Everything was ok during the installation but when i am trying to reach the component from the backend menu i am getting this error:
Fatal error: Class 'KunenaForum' not found in mysite.com/administrator/components/com_kunena/install/model.php on line 1345
I really searched a lot in google to find a solution but no luck!!
Can someone help me ??
PS i checked the Mysql version of my server and is 5.5
Thanks in advance
*** Topics merged ***
Your question has been asked before in this topic. The answer to your question is given in this topic. I hope this helps.
