Do not use this category for:
- asking questions about how to make simple changes to a template designed by the Kunena project team (use K 3.0 Templates instead);
- advertising your own template designs.
Question My cripsis template in Kunena 5.0.1 looks wrong
I just installed 5.0.1 and the problem is taht the template looks like this:
prntscr.com/ccbpw4
Anyone knows how to solve it?
best regards,
Carla
Load bootstrap is selected
but the error continues
the site template is using 'JooSwatch' by joostrap.com
see attachment to see what is happening:
table td[class*="col-"], table th[class*="col-"] {
position: static;
float: none;
display: table-cell;
if I removed the 'float:none;' or changed it to 'float:left' then everything worked correctly.
I changed my Joomla bootstrap.css and no change. Did you mean Kunena's bootstrap file?
col-md is a bootstrap 3 class.
0 - load error: failed to find /home/tresjolie/public_html/components/com_kunena/template/crypsisb3/assets/less/custom.less
I tried all the ideas of above but none worked
backend - components- kunena - template -edit less
then the custom.less file will be created
