Please Read This First:
Do not use this category for:
Question Add file button issue
9 years 5 months ago - 9 years 5 months ago #1 by perryworld
On our site when we try to add a file we have to click on the top half of the button to bring the file select window up.
If we click on the bottom half of the button nothing happens.
When we inspect the elements around the button we noticed the field input.kfile-input is over the top of the button. see attachment
Not sure if this is causing the issue.
Rich
Last edit: 9 years 5 months ago by perryworld.
9 years 5 months ago - 9 years 5 months ago #2 by perryworld
Replied by perryworld on topic Add file button issue
Hi
Is anyone else having this issue.
We have attached our config details
Rich
9 years 5 months ago #3 by 9themestore
Replied by 9themestore on topic Add file button issue
Can you post your site url here? We'll suggest a solution for you. I think, this is a CSS issue.
Regards
The following user(s) said Thank You: perryworld
9 years 5 months ago #4 by sozzled
Replied by sozzled on topic Add file button issue
perryworld wrote: We have attached our config details [as a text file containing BBcode]
Please watch the video vimeo.com/69818669 to learn how to post your configuration report.
9themestore is probably right—it sounds like a CSS problem—but, because we cannot see the problems for ourselves, this problem could be also be caused by a conflict with another Joomla extension. I think you should read My Joomla site template makes a mess of my Kunena buttons .
9 years 5 months ago #5 by perryworld
Hi, thanks for your response.
The site is:
demo.online-communities.org and the login details are:
test
test
Many thanks!
9 years 5 months ago #6 by sozzled
9 years 5 months ago #7 by perryworld
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 192M | Max file upload: 100M
Joomla default template details : gk_publisher | author: GavickPro | version: 3.11 | creationdate: Unknown
Third-party components: Jomsocial 3.1.0.1
Plugins: JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1
9 years 5 months ago - 9 years 5 months ago #8 by sozzled
Thank you for your configuration report (I suggest you edit your message #2 and remove the attached file).
I suggest you update to K 3.0.6 before you do anything else.
I also suggest that you uninstall the Kunena add-ons JomSocial - My Kunena Forum Menu 2.0.3, JomSocial - My Kunena Forum Posts 2.0.3 and JomSocial - Kunena Groups 2.0.3 because these plugins do not work with K 3.0 and they are not supported by the Kunena development team. Contact Jomsocial for updated versions of those plugins.
After you have updated Kunena (to K 3.0.6) and uninstalled the Kunena add-on plugins you were using, see if the problem is fixed.
Last edit: 9 years 5 months ago by sozzled.
9 years 5 months ago #9 by perryworld
I have updated another demo site - demo2.online-communities.org (same login as above). here is the config:
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
9 years 5 months ago #10 by perryworld
Attached are the plugins - I can't see the ones you mentioned?
Many thanks.
Time to create page: 0.547 seconds
