Kunena 6.2.6 released
Question Poll options: Restrictive character limit
In database structure it's allowed for 100 characters for the poll optionKotsolis wrote:
The maxlength=300 didn't fix the issue.810 wrote: 1) if you want alphabetic then you need to enter it alphabetic. In what order you enter, is not a kunena issue.
2) change the maxlength="100" to maxlength="300" or something. And check the width, with inspector or firebug, looks like the css is loaded from your joomla template, so you need to fix that.
Also update joomla, you are using a very old version.
I never used a poll with more than 5 options, i will check where is the alphabetical issue
You haven't fixed it. The poll character limit is 36 characters for me while the .php file says 100. Even the 80 doesn't work.
Thanks.
Only 36 characters limit in each poll option. And when I edit my polls the character limit drops to 25!
The number is too small and it has been reported multiple times. Fix the limit issue. The limit must be up to 99 characters for each poll option.
The names of games or movies are large. Do you test polls?
The fix through edit_editor.php file doesn't work. It was saying 90 characters anyway but I raised it to 300 and still nothing.
check you files if the files are edited:
github.com/Kunena/Kunena-Forum/pull/3239/files
media/kunena/js/poll.js
components/com_kunena/template/blue_eagle/html/topic/edit_editor.php
