Kunena 6.2.6 released
Question Users are unable to change or upload avatar images (Gravatar plugin is enabled)
10 years 9 months ago - 10 years 9 months ago #1 by pilyo
*** Topic split from No avatar upload ***
That is also my problem to one of my sites. Did you find the solution?
Last edit: 10 years 9 months ago by sozzled. Reason: Topic split
10 years 9 months ago #2 by sozzled
How is this problem the same as your problem, pilyo?
Without the Kunena configuration report it's like looking for a needle in a haystack.
Perhaps, in your case, you are using Gravatar avatar images, yes? That is one of (several) reasons why people are unable to upload avatar images. Another reason is that the image is too large to be uploaded. Another reason is that the folder, where the avatar image is to be uploaded, is protected against people creating new files in it. If you search the forum you will find dozens of topics that all have the same subject heading as this topic.
So, until we know more about your site, pilyo, there is no way we can help you. Sorry.
10 years 9 months ago #3 by pilyo
Im sorry and thank you. you simply answered my stupid question. You are right i was using gravatar and disabled it and then my problem was solved.
10 years 9 months ago #4 by sozzled
We are asked about this issue many times. There's no difference to the way people should go about resolving this issue than the way people resolved this issue in K 2.0. For other people reading this topic, they should look at Problems with Gravatar avatar images where the resolution process is discussed in more detail.
If you enable the Kunena - Gravatar plugin then you will not be able to upload a different avatar image on your forum. The whole point about enabling this plugin is for your people to use Gravatar avatars instead of being able to upload something else, assuming, of course, that you and your users know how to use them! ;) if you want to know more about Gravatar avatars, go to the website: www.gravatar.com .
10 years 8 months ago #5 by smOOthMKD
Replied by smOOthMKD on topic Avatar not showing
Hello folks!
I came here because my kunena was not showing the avatars at all. I tried to sneak-peak inside the configuration of my joomla but I didn't find anything unusual. At the place where avatar should appear appears only "user"'s avatar (example: smOOthMKD's avatar)
I made a print screen for you to understand me better
s21.postimg.org/sf35mhl5j/Firefox20130808184254225.png
For additional information - the joomla ftp mode is set to "off" ( maybe this is the problem? )
My configuration:
htaccess: Missing | PHP environment: Max execution time: 10 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : rt_cerulean | author: RocketTheme, LLC | version: 1.1 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.1 | creationdate: 2013-06-29
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Plugins: None
Modules: Kunena Latest 3.0.1
10 years 8 months ago #6 by xillibit
Replied by xillibit on topic Avatar not showing
Check if the avatar is right here in the directory /media/kunena/avatars/... ?
It is happens for all users or only one ?
10 years 8 months ago #7 by sozzled
*** Topics merged ***
smOOthMKD: please see msg #4 of this topic for the answer.
10 years 7 months ago #8 by gonza28
Replied by gonza28 on topic Problem change avatar
Hi guys. sorry, my English is not good.
I need help on my forum avatar.
  I can not change avatar.
loa are upgraded to latest version and still the same. may be my mistake.
I have enabled integration plugin avatar. I have enabled all pictures uploaded to the forum but I see no option to change avatar.
Thank you for your help. a hug
10 years 7 months ago #9 by Jiminimonka
Replied by Jiminimonka on topic Problem change avatar
Post your configuration report please.
Please read the FAQ.
Only one question per topic.
The following user(s) said Thank You: gonza28
10 years 7 months ago #10 by sozzled
Replied by sozzled on topic Problem change avatar
G'day, gonza28, and welcome to Kunena.
I am guessing that you have enabled the Kunena - Gravatar plugin. If you have enabled this plugin, you and your users will use Gravatar avatar images and you cannot change those images in Kunena. You can only change those images if you login to the Gravatar site and change them there. But that's just a wild guess.
Jiminimonka is right. We may be able to answer your question better (and quicker) if we see your configuration report .
Time to create page: 0.430 seconds
