- Thank you received: 1
Kunena 6.2.6 released
Merged K 3.0 Kunena menu issues
- mimimike64
- Topic Author
- Junior Member
mimimike64 wrote: Bonjour et merci mais j'ai tout essayé et rien ne fonctionne. Je vais reconstruire mon site afin de pouvoir installer le version 2.0.
Hello and thank you but I have tried everything and nothing works. I will rebuild my site in order to install version 2.0.
...J'ai recontruit mon site et réinstallé kunena en version 2.0. Tout fonctionne convenablement. J'attends d'avoir plus d'informations concernant la version 3 avant de faire à nouveau une mise à jour. Malheureusement il est impossible , une fois installé la version 3.0 de revenir en arrière...je trouve cela très curieux. Merci de poster si vous avez des news sur l'installation de la version 3.
Recontruit ... I reinstalled my site and kunena version 2.0. Everything works properly. I expect to have more information about version 3 again before an update. Unfortunately it is impossible, once installed the version 3.0 back ... I find it very curious. Thank you to post if you have any news about installing version 3
Oscar2 wrote: I experience a similar problem, and after reading both the forum and the tutorial, still cant figure it out.
I get an error 500 after the update to Kunena 3. The menu is set up fine, I dont have other plugins inside the forum (I disabled uddeium to be sure) and Joomsef is not enabled for Kunena. I use the template Blue eagle 2.0 (version 3.0.0).
Strange thing; the forum doesnt work. The search page does work, but not when I actually search for anything.
Hope I can get some guidement here?
I've tried the solution from the Kunena WIKI, but that didn't help.
Any suggestions?
Link to my forum:
www.bipolarna.se/index.php?option=com_ku...t&catid=0&Itemid=113
you can do that menu...
Regards from Finland
I had 1.074 (yes, 1.074!) attempts to hack the site in one week. So I closed it for all countries but my own (where the visitors are).
But I'll guess my forum thought "Oh shit!" when I posted a new thread here. When I came back to the site the menu suddenly has appeared from thin air...
So all is good. Problem solved.
Thanks!
/Bosse
Mortti wrote: I tried to look that address 2 times... thanks ---> screencast.com/t/wal8fepL
The config report was posted in my previous messages. Thanks!
"Desesperado"
The documenation is here to downgrade : www.kunena.org/docs/K_3.0_Upgrade_Guide#...nena_2.0_is_possible
