Kunena 6.2.6 released
Solved Writing topics always with underscore
Every time I write a topic or a reply in my Kunena, the text is always underscored. When the topic is published it is written correctly but when I edit it is underscored (see attached screenshot)
why?
can someone help me?
Joomla! 2.5.27 Kunena 2.0.4
can you help me?
thanks
2) You have a conflict with a plugin. Unpublish all none joomla/kunena plugins, and look if its works.
For the update, You should enable the error messages on joomla configurations, Set to max and you will see where the error is coming from.
Now I have Kunena Version 4.0.0 but i have the same issue with the underscored text
www.astrotrieste.it/work/index.php?optio...emid=278&layout=list
you can acces with
username: kunena
passwork: kunena
thaaaaaaaaaaaaaaaaaaaaanks :woohoo: :woohoo: :woohoo:
www.astrotrieste.it/work/templates/luchetta01/css/template.css
remove line 880
but the issue persists
