Solved [SOLVED] Kunena Menu at the bottom
8 years 11 months ago - 8 years 9 months ago #1 by nickza
Hello Everyone!
I just wanted to find out if there is a way we can duplicate the kunena menu so it show at the bottom and top of the forum.
I have a few users who would like the menu at the bottom so they do not have to scroll up on long forum posts.
Thanks in advanced!
Last edit: 8 years 9 months ago by nickza.
8 years 11 months ago #2 by sozzled
Replied by sozzled on topic Kunena Menu at the bottom
nickza wrote: I just wanted to find out if there is a way we can duplicate the kunena menu so it show at the bottom and top of the forum.
Yes, it's possible to do this. The Kunena menu is just a Joomla menu. You might like to read Customised menus in the Wiki for more information.
8 years 10 months ago #3 by nickza
Replied by nickza on topic Kunena Menu at the bottom
Thank you.
I am not understanding that wiki. I just want to replicate the menu to display at the bottom of the forum. This explains the menu, but doesn't explain how to do that.
8 years 9 months ago #4 by nickza
nickza wrote: Thank you.
Bump.
8 years 9 months ago #5 by 810
Replied by 810 on topic Kunena Menu at the bottom
components\com_kunena\template\blue_eagle\html\default.php
add on line 22:
$this->displayMenu ();
8 years 9 months ago #6 by nickza
thank you.
Is it not "display.php instead of default.php?
I do not have a default.php in that directory
810 wrote: components\com_kunena\template\blue_eagle\html\default.php
add on line 22:
8 years 9 months ago #7 by 810
yes, should be display.php
8 years 9 months ago #8 by nickza
Thank you again.
I just want to be sure, because it does not make sense as to where you suggest I place that code:
<?php /** * Kunena Component * @package Kunena.Template.Blue_Eagle * * @copyright (C) 2008 - 2015 Kunena Team. All rights reserved. * @license http://www.gnu.org/copyleft/gpl.html GNU/GPL * @link http://www.kunena.org **/ defined ( '_JEXEC' ) or die (); ?> $this->displayMenu (); -LINE 22 <div id="Kunena" class="layout container-fluid"> <?php if ($this->ktemplate->params->get('displayMenu', 1)) { $this->displayMenu (); } $this->displayLoginBox (); $this->displayBreadcrumb (); // Display current view/layout $this->displayLayout(); $this->displayBreadcrumb (); $this->displayFooter (); ?> </div>
8 years 9 months ago #9 by 810
it should be under:
8 years 9 months ago #10 by nickza
Working Perfectly. Thank You
Time to create page: 0.543 seconds
