Kunena 6.2.6 released
Solved A new topic or answer is not posted (visible)
8 years 11 months ago #1 by Beddesprei
If i make a new topic it isn't visible on the forum.
How is that possible?
8 years 11 months ago #2 by 810
are the topic maybe under review? backend - kunena - category manager - select category - check the settings
8 years 11 months ago - 8 years 11 months ago #3 by Beddesprei
No, not under review.
Even i will change my birthday (and saved it) is not possible.
Last edit: 8 years 11 months ago by Beddesprei.
8 years 11 months ago #4 by 810
could you add the kunena report
8 years 11 months ago #5 by Beddesprei
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 16M
Joomla default template details : rt_corvus | author: RocketTheme, LLC | version: 1.7 | creationdate: Unknown
Kunena default template details : NTS KMaterial | author: Nice Theme Store | version: 3.5.2 | creationdate: 2015-03-15
Kunena version detailed: Kunena 3.0.8 | 2015-04-05 [ Imperium ]
Plugins: None
8 years 11 months ago #6 by 810
ok, see no isse there, could you make screenshots from the category settings.
Backend - kunena - category manager - select category
8 years 11 months ago #7 by Beddesprei
8 years 11 months ago #8 by Beddesprei
i can make more screenshots if it is nescessary.
8 years 11 months ago #9 by 810
one from the permissions tab
8 years 11 months ago #10 by Beddesprei
Where can i find it?
Time to create page: 0.431 seconds
