- Thank you received: 1434
Kunena 6.2.6 released
Solved Can't insert image into post with the "Insert" button
8 years 7 months ago #11
by 810
Replied by 810 on topic Can't insert image into post with the "Insert" button
could you check if you have the problem with the default kunena template. Maybe the bug is on your kunena template.
- YonisHobby
- Topic Author
- Junior Member
8 years 6 months ago #12
by YonisHobby
Replied by YonisHobby on topic Can't insert image into post with the "Insert" button
Yes, tested with other template (on a test environment as it break the view) and still can't insert any attachment.
I tried to mark each one as default, the template changed but it didn't solve the problem:
8 years 6 months ago #13
by 810
could you create a account on your site, so I can check whats wrong.
8 years 6 months ago #14
by rich
Replied by rich on topic Can't insert image into post with the "Insert" button
I see on your image that no default template is selected.
- YonisHobby
- Topic Author
- Junior Member
8 years 6 months ago - 8 years 6 months ago #15
by YonisHobby
810: I created the following account:
This is a direct link to create new topic: (As the forum is in Hebrew)
www.tissan.co.il/forum/מגדל-הפיקוח/topic/create
Rich: I tested both templates on a second server, the same behavior. Pressing any of the 3 buttons related to attachment will open the Windows Explorer window to look for a file to upload.
Can't insert or remove the file.
Once I added an attachment and submitted to the topic, I can edit the post and then can insert the attachment into the message.
Please notice that you can add attachment just can't insert them into the post in the first edit.
Last edit: 8 years 6 months ago by rich. Reason: Account made invisible for other users
8 years 6 months ago - 8 years 6 months ago #16
by 810
try this:
Template manager
Select your template, select edit css.
select custom.css
Add this:
Template manager
select custom.css
Add this:
#Kunena .kfile-input { right:auto !important; }
Last edit: 8 years 6 months ago by 810.
The following user(s) said Thank You: YonisHobby
- YonisHobby
- Topic Author
- Junior Member
8 years 6 months ago #17
by YonisHobby
Yes !!!
Finally it works. Thank you very much.
Time to create page: 0.389 seconds
