Solved Points not updated when posting
11 years 3 weeks ago #1 by softstor
I have just installed AUP and enabled the Kunena AUP plugin. I have then done the following:
1. Added the Kunena points under the rules for new posts and replies.
2. Edited the AUP configuration.
3. Did a User Sync.
I then did a sample post in the forum and no points were generated.
Is there something else that I need to configure?
Visit my Kunena Forum at www.ProsperityTeamOne.com
11 years 3 weeks ago #2 by xillibit
Can-you please paste your Kunena report configuration settings here ?
11 years 3 weeks ago - 11 years 3 weeks ago #3 by softstor
htaccess: Exists | PHP environment: Max execution time: 1000 seconds | Max execution memory: 64M | Max file upload: 100M
Joomla default template details : corporate_response | author: Shape5.com | version: 1.0 | creationdate: June 2012
Third-party components: AlphaUserPoints 1.8.3
Plugins: None
Last edit: 11 years 3 weeks ago by softstor.
11 years 3 weeks ago #4 by softstor
I have visited the AUP forum and a lot of people are having the same problem. It seems that Kunena no longer works with AUP. Many people have suggested its a problem with the Kunena Rules in AUP.
11 years 3 weeks ago #5 by sozzled
Try this: Go to the Kunena Control Panel (in the backend) and then select Kunena Plug-ins.
Next, set the plugin parameter settings as follows:
Enable Activity Stream = Yes
... and then enable (publish) the plugin. You may need to also set a value for the setting Earn Points Limit
See if that makes a difference to you.
The following user(s) said Thank You: softstor
11 years 3 weeks ago #6 by softstor
Thank you.
Setting the Activity Stream solved the problem.
11 years 3 weeks ago - 11 years 3 weeks ago #7 by sozzled
Can you please go back to the forum at AlphaUserPoints and let the other people there - who said they could not make this work and suggested that "Kunena no longer works with AUP" - that you solved your problem and how you went about solving the problem. People should also remember that the forum at AlphaUserPoints is based on K 1.6.1 and that forum may not be a good example of using AUP with K 2.0.4 It may also be a good idea for people, who are registered on the AlphaUserPoints website to let the site administrators at that site know that their Kunena forum is out of date and should be updated.
Thank you for letting us know. This topic can now be marked as resolved.
Last edit: 11 years 3 weeks ago by sozzled.
11 years 3 weeks ago #8 by softstor
Yes I will do that.
11 years 3 weeks ago #9 by sozzled
Thanks. K 1.6.1 did not have these integration plugins . It may be worth letting the developers of AUP know about these things that exist in K 2.0.4. It may not have occurred to them about the solution that I have told you about and it will help people who use AUP with K 2.0. ;)
11 years 3 weeks ago #10 by netstyler
We had the same problem, that the Kunena Rules for alphapoints did not work anymore.
I did fix the issue see here:
www.alphaplug.com/index.php/forum/27-kun...ena-rules-fixed.html
Perhaps this helps someone ;)
Time to create page: 0.547 seconds
