Merged Kunena, Gantry Component And Profiles Edit
12 years 9 months ago - 12 years 9 months ago #1
by alakentu
KS!
NO hacer Spam | NO esbribas todo en mayúsculas | Sigue las reglas
Kunena, Gantry Component And Profiles Edit was created by alakentu
Hi all,
If a user uses templates to implement the component Gantry (E.g. Rockettheme Templates), some of its plugins, or modules, many times and in most cases can cause errors when editing user profiles Kunena when this does not have any integration.
This I have detailed in my forum and many of my users had the same problem, the solution to this "headache" is simple.
We go to template manager and select the default template to use Gantry, the tab "Advanced" we see the "Build Spans Titles" which by default will be "ON", switch to "OFF" and save the changes.
And with that we can edit our profiles should be.
Kind regards
Kind regards
KS!
Last edit: 12 years 9 months ago by alakentu.
12 years 9 months ago #2
by cmurphy
Replied by cmurphy on topic Re: Kunena 1.6.4, Gantry Component And Profiles Edit
This does not work, at least for the Rocket Theme template "Tachyon". As a matter of fact, the setting you speak about "Build Titles Spans" is already "OFF" by default.
Just for shnits and giggles i turned it on, tried it with no luck, then turned it back off again, same result.
We are unable to edit user profiles. The tabs show up on the edit screen, but they are not clickable, nor is any profile info displayed on the page.
A fix for this would be AWESOME!
Using the following:
Joomla 1.5
Kunena 1.6.4
Template: Rockettheme Tachyon for J1.5
Joomla 1.5
Kunena 1.6.4
12 years 9 months ago - 11 years 11 months ago #3
Replied by sozzled on topic Re: Kunena 1.6.4, Gantry Component And Profiles Edit
See msg #1 of If you are having problems with K 1.6, please read this firstcmurphy wrote: A fix for this would be AWESOME!
Last edit: 11 years 11 months ago by sozzled.
11 years 11 months ago #4
by xoofx
Replied by xoofx on topic Kunena 1.6.4, Gantry Component And Profiles Edit
Note that if you still want to keep "Build Spans" gantry feature, you can modify one file in gantry to make it working with Kunena Edit User Profile.
Check this post.
Check this post.
Time to create page: 0.541 seconds
