Kunena 6.2.6 released
Use this category:
Use this category:
Question Uncaught TypeError: jQuery(...).modal is not a function at beforeInsert
5 years 2 months ago #1
by Boby71
After updating to 5.1.8 today, my editor doesn't work fully - some buttons (e.g. inserting links, pictures) causing the following error:
at beforeInsert (markitup.editor.js:60)
at prepare (markitup.js:288)
at markup (markitup.js:360)
at markitup.js:230
The line numbers with the error are depending on the function I've tried to execute.
Kunena Version: 5.1.8
Blue Eagle 5 template: 1.5.2
Any ideas what I could do?
Thanks, Boby
at markitup.js:230
Thanks, Boby
5 years 2 months ago #2
by 810
Replied by 810 on topic Uncaught TypeError: jQuery(...).modal is not a function at beforeInsert
update to Kunena 5.1.9, then check if it has been fixed, else go to kunena - plugins - rebuild
5 years 2 months ago #3
by Boby71
Replied by Boby71 on topic Uncaught TypeError: jQuery(...).modal is not a function at beforeInsert
Thank you, but where can I get it from? The download link still only offers 5.1.18:
www.kunena.org/download
5 years 2 months ago #4
by 810
a thnx will update it. You can also check the backend, you should see a update.
5 years 1 month ago #5
by Boby71
Installed 5.1.9 and rebuilt all plugins - no change; when I try to insert an URL I get:
What else can I check?
Thanks,
Boby
at markitup.js:230
beforeInsert @ markitup.editor.js:60
prepare @ markitup.js:288
markup @ markitup.js:360
(anonymous) @ markitup.js:230
setTimeout (async)
(anonymous) @ markitup.js:229
dispatch @ jquery.min.js?55f439cecf2ac189140bab6a72b8b517:2
v.handle @ jquery.min.js?55f439cecf2ac189140bab6a72b8b517:2
Thanks,
Boby
4 years 9 months ago #6
by leneborma
Replied by leneborma on topic Uncaught TypeError: jQuery(...).modal is not a function at beforeInsert
The $(…).
modal
is not a function is usually caused because scripts are loaded in the wrong order . The browser will execute the scripts in the order it finds them. If in a script you attempt to access an element that hasn't been reached yet then you will get an error. Make sure that you don't have a script above one that it requires.
Plugin dependencies
Some plugins and CSS components depend on other plugins. If you include plugins individually, make sure to check for these dependencies in the docs. Also note that all plugins depend on jQuery (this means jQuery must be included before the plugin files).
Multiple jQuery instances
Sometimes this warning may also be shown if jQuery is declared more than once in your code. The second jQuery declaration prevents bootstrap.js from working correctly. The problem is due to having jQuery instances more than one time. Take care if you are using many files with multiples instance of jQuery. Just leave one instance of jQuery and your code will work.
Plugin dependencies
Time to create page: 0.381 seconds
