- Thank you received: 145
Use this category:
Use this category:
Solved Blue Eagle 5
5 years 6 months ago #11
by Leen
L.v.d.A
Replied by Leen on topic Blue Eagle 5
Then maybe something wrong with installing Kunena.
Or check out the administrator section
menu Extensions> manage> discover click above left
discover the button and if any kunena appears, check it and press the other Install button.
otherwise Download kunena again and then install it again.
L.v.d.A
- AnandGIBES001
- Topic Author
- Junior Member
5 years 6 months ago #12
by AnandGIBES001
Replied by AnandGIBES001 on topic Blue Eagle 5
This is the same thing I have been trying to convey it to you and have tried all possible ways to install the template but haven't been able to install the template.
I have taken the following steps to install kunena template:
1. Downloaded template - www.awesomescreenshot.com/image/3599845/...bac531620ae6cb4ded19
and then tried to install but it is not installing and showing an error.
2. Then again I downloaded from www.awesomescreenshot.com/image/3599847/...ad67ab42db59b7b10695
and tried to install but it is not installing and showing an error.
3. Then again I have been through www.kunena.org/docs/en/manual/backend/templates/add-template
but as THERE IS NO KUNENA DASHBOARD IN MY JOOMLA ADMIN - I could not install the template.
So now how to install the template.
Regards.
Regards.
- Thank you received: 35
5 years 6 months ago #13
by Pinkeltje
Replied by Pinkeltje on topic Blue Eagle 5
It's not necessary to shout.
Please read this first: www.kunena.org/docs/en/basics/installation
- AnandGIBES001
- Topic Author
- Junior Member
5 years 6 months ago #14
by AnandGIBES001
I never meant to shout, I was letting you know of all the things I have been doing to install the template and I mentioned them point wise so that if I have missed any step you would be able to let me know.
Thanks for the help.
Regards.
Regards.
5 years 6 months ago #15
by Leen
L.v.d.A
I think there is a misunderstanding.
You first downloaded first kunena dowload and install it the forum extension kunena and
installed in your joomla site?
and after that you can only install that template in kunena itself.
L.v.d.A
5 years 6 months ago #16
by rich
Replied by rich on topic Blue Eagle 5
@AnandGIBES001
First create a backup from your page, then you can send me the access data for your backend to [email protected] (address without star).
- AnandGIBES001
- Topic Author
- Junior Member
5 years 6 months ago #17
by AnandGIBES001
Thanks for the help, it finally got installed.
Regards.
Regards.
Time to create page: 0.436 seconds
