Solved How to remove this x
4 years 1 month ago #1
by NikoBic63
How to remove this x was created by NikoBic63
How to remove this x that appears when I open the forum?
4 years 1 month ago #2
by rich
Replied by rich on topic How to remove this x
I'm sorry, but how should we help you if you only add an image and no other information? Probably will this x caused by your Joomla template or an extension.
Please add a configuration report: docs.kunena.org/en/faq/configuration-report
The following user(s) said Thank You: NikoBic63
4 years 1 month ago - 4 years 1 month ago #3
by NikoBic63
Replied by NikoBic63 on topic How to remove this x
The problem was in Module mod_bt_login, thanks!
Last edit: 4 years 1 month ago by NikoBic63.
4 years 1 month ago #4
by rich
Now you should also repair the menu item "Forum" in your top menu.
Please see here:
docs.kunena.org/en/troubleshooting/menu-issues
docs.kunena.org/en/faq/kunena-menu
Ah... therefore I could not see this issue.The problem was in Module mod_bt_login, thanks!
Please see here:
Time to create page: 0.472 seconds
