Solved How to put kunena navigation on top bar of my template
- nhoj050789
- Topic Author
I have a problem on kunena menu I was trying to put it on the top of my page using module position (which is breaking news) www.screencast.com/t/vezjEADj
Instead of its original position inside the kunena template but its showing a different looks and the login/profile on the right side is not showing when I tried to put it on module position www.screencast.com/t/UeKYsJG0
Question: is there a shortcode to use to put on module as script so I don't need to style it manually so its looks same on the original?
Also the kunena menu is working fine on other page but on the other page its showing blank like this www.screencast.com/t/K6pwGIOK which is not good please help me to sort this issue thanks
in joomla module management and module type menu
and there you can then choose the basic menu and also the menu
where to start.
You just have to put it in the right position depending on your template positions.
L.v.d.A
- nhoj050789
- Topic Author
what I have last week when I place it on module is a plain vertical menu from kunena ,
Any suggestion if there's a script shortcode to get the exact navigation
- nhoj050789
- Topic Author
the same as Kunena's.
and then add it to the menu option of a template, it seems to work nicely.
But if I add it to a new menu module and in a different position. I get a vertical menu again.
L.v.d.A
The login form is not a menu item therefore you have this not in a copy of the menu. If you want the Kunena menu on top, why don't you move it via CSS to this position? As you can see in this forum here we have placed the menu on the fix top position.Instead of its original position inside the kunena template but its showing a different looks and the login/profile on the right side is not showing when I tried to put it on module position
I think you use Kunena menu items in other menus. Please see this docs:Also the kunena menu is working fine on other page but on the other page its showing blank
docs.kunena.org/en/troubleshooting/menu-issues
docs.kunena.org/en/faq/kunena-menu
- nhoj050789
- Topic Author
So I think something will have to be adjusted in a custom.css
And without a real link to the website, it remains a bit guessing
where the problem may be
L.v.d.A
- nhoj050789
- Topic Author
