Kunena 6.2.6 released
Solved Problem with showing icon or filename at downloads
4 years 6 months ago #1 by fchojinski
my problem is: When i add a file for download to a post no icon will be shown. Otherwise, how can i change from showing icon to show the filename?
I am using mamp on windows 10, joomla 3.9.8 and kunena 5.1.3
Please look at my screenshot. Thanks in advance for every help.
Regards
Frank
4 years 6 months ago #2 by Leen
which kunena template do you use?
and the last kunena is now 5.1.14 maybe first update
L.v.d.A
4 years 6 months ago #3 by fchojinski
Hi Leen,
i have now made an update. The template is Crypsisb3. I noticed now that e.g. jpgs are shown, PDF not. Is it because of the file type? See screenshot.
Regards
Frank
4 years 6 months ago #4 by Leen
Hello Frank
I have looked at my own test site's but also I cannot make a pdf icon visible.
I found here on Github kind of the same question
PDFs in messages
L.v.d.A
4 years 6 months ago - 4 years 6 months ago #5 by fchojinski
Hi Leen,
thanks a lot for your help. I will take another way and integrate the link into the text like this
Then for me it´s ok.
Greetings
Frank
Last edit: 4 years 6 months ago by fchojinski.
Time to create page: 0.366 seconds
