Kunena 6.2.6 released
Solved migration probs from J 1.5 to J 3
4 years 9 months ago #1
by martinsai
migration probs from J 1.5 to J 3 was created by martinsai
Hi Guys,
I need to transfer kunena including all content like messages, categories from a Joomla 1.5 (Kunena V 1.5.12) website to latest Joomla Version with Kunena 5.1.12.1
So far I have installed the component succesfully. I also could import/export the Joomla Users to the new Kunena forum.
I read in tutorials that I just have to export from old Kunena data tables and import them into new mysql.
1.Prob: I have migrated the categories and the messages for instance but in new Joomla/Kunena admin panel the categories are not displayed. I also renamed the table from xxx_fb_messages to xxx_kunena_messages. same with categories but they are not displayed.
what have I done wrong? I also pressed the repair button in Joomla backend > Extesnions > Data Base, but no success.
2. Prob: the old kunena version has different data tables names and structure. What is there to do so that kunena will run again on new version?
cheers and thnx a lot, martin
4 years 9 months ago #2
by rich
Replied by rich on topic migration probs from J 1.5 to J 3
Your steps are all wrong.
2. Afterwards delete all Kunena tables in your new web page.
3. Import all old Kunena fb tables and change the prefixes of the fb tables to your new prefixes xxxx_fb_
4. Now you must go back to an old php 5 version, otherwise is step 5 not possible!
5. Install as intermedia step Kunena 4.0.12 (Kunena recognices the old tables and migrated this tables to the new structure)
github.com/Kunena/Kunena-Forum/releases/tag/4.0.12
6. Upgrade Kunena
7. Joomla 1.5 has another user management as Joomla 3.9. Therefore you must after the migration adjust all category permissions manually, otherwise users have no access and can't see the categories.
8. Check if all works
9. Now you can change again to the current php version
10. If you want, you can delete now all fb tables. They are not needed anymore after a successful migration.
1. You must import the Joomla users to the new Joomla, not to Kunena! The Joomla users must be the same!I also could import/export the Joomla Users to the new Kunena forum.
6. Upgrade Kunena
4 years 9 months ago #3
by martinsai
Replied by martinsai on topic migration probs from J 1.5 to J 3
Dear Rich,
thnx a lot!!!!!!!!!!! I did all steps and it worked fine! I was on the wrong path!
I just saw now that the default category view looks very different to the old default template. I purchased the Blue eagle 5! and it works, great!
Now 2 questions: how can I remove the tooltipps over the category title links?
if I want to create new topic, there are many parameters to be filled out like "Confirm the text to be exchanged" or " Image configuration....
(see image) how to remove all that?
cheers
martin
cheers
martin
4 years 9 months ago #4
by rich
Which Joomla template use you and have you installed Blue Eagle correct?
docs.kunena.org/en/manual/backend/templates/add-template
Maybe your Joomla template does not use bootstrap.css. If it so, then choose in the Blue Eagle template setting Load bootstrap css.
4 years 9 months ago #5
by martinsai
Rich you are just great!
both probs solved. Template was correctly installed, I loaded bootstrap and now both props are gone! thnx again!
cheers, martin
cheers, martin
Time to create page: 0.393 seconds
